2 members (78buckshot, Wheelie), 131 guests, and 2 robots.
Topics128,128
Posts1,056,358
Members48,441
#173876 04/30/2005 7:25 AM
First, thanks for getting the site back up. I was going through withdrawals, and was going to have to substitute buying stuff I don't want on eBay.
Anyone got monoleaf springs on an AD? Are they a good/bad thing? What about having the old ones re-arched? What does it cost? Would they need re-arching again soon--like, do you just get into a situation of diminishing returns? Is it better to renew them? There seems to be quite a spread in the price of new springs from one supplier to another.
Also are there adaptors to mount an original steering wheel on a tilt column? If not, is there some way to cobble them together? I have an aftermarket wheel on my tilt but would prefer the look and feel of an original.
Any pearls of wisdom, gang?
I have new springs ont he front of my 51,3100,that I bought from patricks. they are a four leaf pack.they lowered the front about two inches and make the truck ride and handle nice, old navy 51....
Thanks for the input guys. I'd welcome some more also. And should have said the springs I have in mind are the rear (54 1/2 ton). Christian
Hey Joe
Interesting post re Caravan springs. I made a trailer out of the rear of a five-bolt Caravan rear end (Grand Caravan, I think). The trailer rides well, but I'm leary of more than 1500 lbs in it. I did a top soil run once. Was supposed to get 1/4 yard (probably closer to 1/3-1/2). The springs reversed and bottomed out. Made it home okay, and the springs returned on emptying the trailer. I'm sure someone here has a better estimate of the actual load than I do, and I pulled it!
So can anyone help me out with info re monoleaf springs v. re-arching the old multileaf springs v. buying new? And info about how to mount a stock AD wheel on a tilt?
