| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | First, thanks for getting the site back up. I was going through withdrawals, and was going to have to substitute buying stuff I don't want on eBay.
Anyone got monoleaf springs on an AD? Are they a good/bad thing? What about having the old ones re-arched? What does it cost? Would they need re-arching again soon--like, do you just get into a situation of diminishing returns? Is it better to renew them? There seems to be quite a spread in the price of new springs from one supplier to another.
Also are there adaptors to mount an original steering wheel on a tilt column? If not, is there some way to cobble them together? I have an aftermarket wheel on my tilt but would prefer the look and feel of an original.
Any pearls of wisdom, gang? | | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I have new springs ont he front of my 51,3100,that I bought from patricks. they are a four leaf pack.they lowered the front about two inches and make the truck ride and handle nice, old navy 51.... | | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | Thanks for the input guys. I'd welcome some more also. And should have said the springs I have in mind are the rear (54 1/2 ton). Christian | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Hey Joe Interesting post re Caravan springs. I made a trailer out of the rear of a five-bolt Caravan rear end (Grand Caravan, I think). The trailer rides well, but I'm leary of more than 1500 lbs in it. I did a top soil run once. Was supposed to get 1/4 yard (probably closer to 1/3-1/2). The springs reversed and bottomed out. Made it home okay, and the springs returned on emptying the trailer. I'm sure someone here has a better estimate of the actual load than I do, and I pulled it!
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Apr 2005 Posts: 151 Member | | Member Joined: Apr 2005 Posts: 151 | So can anyone help me out with info re monoleaf springs v. re-arching the old multileaf springs v. buying new? And info about how to mount a stock AD wheel on a tilt? | | |
