0 members (), 116 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#173166 04/06/2005 9:53 AM
Junior Member
Junior Member
Hi, can anyone tell me the correct (or best in practice) tire pressures for a '64 C10?
I'm assuming that when its unladen (ie most of the time) the rears won;t need much pressure.
Thanks, Limey Simon
#173167 04/06/2005 10:47 AM
why not go with the mfg.'s recommended p.s.i. cold? as stated on the sidewall?
it ain't yours till you bleed for it...
i reject your reality and substitute my own...
"morticia" a 69 c-10 (original)
97 ram
Junior Member
Junior Member
Good idea but I'm pretty sure most tires say the maximum pressure, obviously not specific to an individual vehicle
Anyone got a '64 C10 handbook with it listed please?
#173169 04/06/2005 11:12 PM
Riding in the Passing Lane
It depends on the tire size. I carry 40 psi in front & 32 in the rear. You could run a little less in front with power steering.
1972 Chevy c10 Cheyenne Super
I run 35 PSI all around in the summer and 30 PSI all around in the winter,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Chevy shop manual says 35 psi for a 15 in. tire.
However, this is for bias ply tubeless tires. I run 35 in the radials on my '66. You don't want to fill the tire to "max" pressure. The truck will ride like a brick!! Not to mention tire wear issues. You'll be fine with 35 psi all around. For heavy duty operation, you could increase pressure by 5 psi. Just don't forget to adjust the pressures back to 35 psi when unlaiden.
Jim Sgrig
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
