| | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 48 Junior Member | | Junior Member Joined: Jan 2005 Posts: 48 | Hi, can anyone tell me the correct (or best in practice) tire pressures for a '64 C10? I'm assuming that when its unladen (ie most of the time) the rears won;t need much pressure.
Thanks, Limey Simon | | | | | Joined: Apr 2005 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 20 | why not go with the mfg.'s recommended p.s.i. cold? as stated on the sidewall? | | | | | Joined: Jan 2005 Posts: 48 Junior Member | | Junior Member Joined: Jan 2005 Posts: 48 | Good idea but I'm pretty sure most tires say the maximum pressure, obviously not specific to an individual vehicle
Anyone got a '64 C10 handbook with it listed please? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It depends on the tire size. I carry 40 psi in front & 32 in the rear. You could run a little less in front with power steering. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I run 35 PSI all around in the summer and 30 PSI all around in the winter, Scott | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Chevy shop manual says 35 psi for a 15 in. tire. However, this is for bias ply tubeless tires. I run 35 in the radials on my '66. You don't want to fill the tire to "max" pressure. The truck will ride like a brick!! Not to mention tire wear issues. You'll be fine with 35 psi all around. For heavy duty operation, you could increase pressure by 5 psi. Just don't forget to adjust the pressures back to 35 psi when unlaiden.
Jim Sgrig | | |
