2 members (kades51, tclederman),
106
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I need your help gang. When I bought my truck it had a hole in the cab. I assumed it was for a radio antenna but as I found out it is not in the stock location. Please look at the picture and help try to figure out what it is for. [img] http://img.photobucket.com/albums/v374/55chevy/HoleinCab.jpg[/img] Thanks, Chris
Chris 1955FirstSeries
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Looks like the hole, where the shaft of a Spotlight came through. Does it go all the way through, to the inside of the cab. If so, that's what it is. | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | You know I never looked on the inside of the cab. Will be sure to do that tonight. I wonder why there is no place for a radio antenna. Were radio's an option and if you opted not to there wasn't a place for them on the cab?
-Chris
| | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Chris-
Most radio antennas were mounted on the flat surface of the cowl in a way to avoid a bash by the hood when opened. On my rig, someone drilled the atenna hole without checking for hood clearance. Open the hood, end of antenna! Relocation is one of my summer projects!
The hole you have fits with the spotlight option, but could be converted for pillar mounting of the antenna. | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Well thanks gang for the input. Any idea where I can get antenna to work for a radio?
-chris
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Chris, if you want the original style antenna, most of the AD truck suppliers carry them. The original style antenna mounted on the driver's side cowl in a very specific location. They also have a metal bracket inside that attaches to the inside side cowl metal. The antenna should come with a mounting layout pattern. | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | That hole is way to small for a spotlight.
Gangster whites and straight pipes.....
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Yeah I am looking for some after market antenna to use for my radio if I ever get that far along.
-Chris
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Depends on the brand of Spotlight used, as to wheather yhe hole is too small, or not. One of the '48 Chevrolet Parts trucks, I have, had two spotlights on it originally, & the holes, are about the size of a Dime. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | It looks like spotlight and then the hole was filled partially when they preped the body for paint. When the body was preped they didn't fill it because they weren't sure what it was for. My best guess. Cecil......... | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Chris that hole is where a spotlite was mounted at one time.As for the antenna,I would check the auto parts out for a wire antenna you can tape on the winshield inside.Drilling holes sucks.The cars had this type on antenna put in factory windshield in the 60-70+ also check out the CD players No antenna needed.Just listing to the motor purr is good enuff for me.
dan-pa
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wouldn't the spotlight also have had an outside bezel that had 2 screws to clamp it against the post? where're those holes?
Bill | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Chris I decided to go with a dual-mount antenna on my truck ... check it out Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | Originally posted by spanky: Depends on the brand of Spotlight used, as to wheather yhe hole is too small, or not. One of the '48 Chevrolet Parts trucks, I have, had two spotlights on it originally, & the holes, are about the size of a Dime. I have had alot of spotlights but have never seen one with a shaft that small.There would also be 2 screw holes for the mounting bracket. It maybe a hole for those "dummy" spotlights and the other hole got covered during the prepwork.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Sorry, Not on this one I have. My brother removed the spots, off of it, personally. Only had one smaller hole, for the mounting bracket, on each side.. | | | | | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I looked last night and there was no indication of a second hole on the inside where a spotlight handle would be.
The only guess I can come up with is it was a hole drilled by the P.O. and used as an antenna for the crappy radio I pulled out.
My plan is to hit Napa or Autozone and locate a antenna I can use for a radio/cd player that I plan to mount under the seat.
Thanks everyone,
Chris
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Alan..was wondering where you got that antenna...checked my Chevy Duty catalog, and you are right..looks pretty cheap.. I tried to find one on Truck Shop, but their online catalog leaves a lot to be desired...I mounted a spring base antenna on the cowl about 2yrs ago without thinking about opening the hood, but it works pretty well as it just springs back a little when the hood is open...really want to do one likes yours though..love the look | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Shooper
I would phone Chevy Duty and the Truck Shop and ask if their mounts are stainless or plastic, making sure they know I don't like the idea of plastic.
Last time I looked, I thought the Truck Stop had the right one.
Chevy Duty: 1-800-741-1678
Truck Shop: 1-800-243-8947
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | I can appreciate the kid's car seat in your truck! Start 'em off young!
A man is like an old truck... He will rust out before he wears out...
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Hey Chris55.1 I don't know what the hole is for but I would like to know what color that is on the truck.Weeds | | |
