| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I'm curious to see if anyone has any pics of a hitch on their stovebolt truck. I'm sure any hitch would have to be a custom job. I haven't seen any hitches that are made for this generation of truck.
Reason I ask is because mine is a 3/4 ton, and to get a hitch on it, I have to drop it down pretty low since the back end is so high up. If I do that, the hitch effectively becomes the bumper because it's car-height.
Any custom hitch installations out there? Thanks.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i think you are right about the custom part. i have called e-mailed and tried everywhere. i did see an adustable hitch at auto zone for about 100.00. i think it will work. hidden hitch makes them for 59 and up but not for the earlier ones. a local tire shop says can get me one but i am not sure he is right. don't give up and let us all know if you find one plEEEEEEEEEEEase.. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | hrd, had a hitch made for my panel awhile back and just got a digital camera, i'll try and send some pics to you when the ice thaws. tony'n weatherford  | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you can weld, your local farm and fleet stores carry the parts you need to build your own hitch. Then to get the heighth you want, you buy the appropriate drop hitch for your receiver. I've adapted several hitches from take-offs for my trucks. A little welding, a little drilling, you have hitch. Scott | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Here you go, this the the hitch on my 1940 3/4 ton. This is very old custom work including the flatbed. 1940 3/4 ton hitch | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I don't know what year your truck is, but i tok one from a dodge mini-van and narred it down for my 64. The drop is perfect and looks just like it was made for my truck. | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Excuse my spelling! That is why you should proofread before you post. I took one from a dodge mini-van and NARROWED it down. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I thought you just spelled it like its said "narred". Seems right to me. Brian | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | I've got a custom hitch. Easy to make, easy to weld. Very strong. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Okay. I went ahead and installed the hitch I picked up last summer at a swap meet. All I know about it is it's a really rugged GMC/Chevy truck hitch that is rated at 1000 pounds tongue weight and 8500 pounds towing capacity. I bolted AND welded it to the frame. All I had to do to make it work was cut about an inch of metal off the mount surface to clear the spring mounts on the frame.
Even though it drops down to the right height for a conventional ball receiver, which makes it kind of obvious back there, I will install a bumper above it to partially dress it up a little nicer.
I really think a higher hitch would look better, and then a drop down ball to make the hook up the right height for trailers, etc.
BTW, it makes a really nice step to get up into the bed...as long as the tailgate is not down.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | I just spoke to the people at Hidden hitch. Nothing for 55-59 Chevy trucks. I would like to install a hitch on my '59 fleetside to pull my newly aquired '51` teardrop trailer. Any suggestions?
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | 4d9r, go look at auto zone they have an adjustable hitch, for width. i you use it let us know , i am going to try later in the year. if the beds are the same for 54 to 82 chevy stepsides arre the frames? i know the fenders are wider but is there any other changes? you would think that a hitch for a later model would fit. must be the old computer glitch if the computer doesn't say so it doesn't work. all the old knowledge has retired. another soap box for another time. ron
