1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | Folks,
I have a pair of two-piece, split-rim artillery wheels, 16", 6-lug, that fit the old chevies (they were on my '47 sedan when I got them). I have never heard of GM using split artillery rims, only solid ones. I emailed the folks at Jim Carter's and they told me this is not a GM wheel (although it fits the GM 6-lug hub). Any ideas on what these wheels possibly came off of? Judging by what I've seen the solid arty wheels go for on ebay, I think they might fetch a few bucks, and I'd like to sell them so I can continue to pour money into my old chevies. Thanks for the input.
Tyler | | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I'm not sure, but I have three :mad: of the same. I'm curious to find out as well.
Your lack of preparation is not my emergency
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | those rims are unsafe.Many state inspection not aloud.split rims are history.Take them to the bone yard .I also have 4 of those rims on a early 55 3/4T
dan-pa
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Split rims are not unsafe per se. Damaged or rusted out split rims are unsafe. I've never heard of them being "not aloud". Do you mean "not allowed"? I've never heard of any factory configuration not being allowed on an old vehicle.
But if you want to send them to a bone yard you can send them to mine. | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | thats funny I have never seen six hole wheels on 3/4 ton expt for mabe some realy old chevys (35-37?) | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | The first year Chev. made a 3/4-ton was 1937. The 3/4-tons shared the 6-bolt axles and drums with the 1/2-tons until 1946 when they got the heavier 8-bolt parts that we now associate with 3/4-tonners. The standard wheel on the '37-'42 3/4 was the 15 x 5-1/2" artillery wheel which is highly valued today since it looks good and will take a modern 15" radial tire. This 15" wheel was an option on the 1/2 tons. Heavy duty 3/4 tons in those years came with an odd looking 17" wheel. Some earlier Chev. cars came with a narrow 16" artillery wheel which has very little value. I have never seen a 16" split rim artillery wheel. Can you maybe post a picture of the wheel in question? | | | | | Joined: Nov 2002 Posts: 59 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Nov 2002 Posts: 59 | Is this wheel riveted or welded together?
Local welding shops used to weld the wider split rims on the customers orginal wheel centers to increase the load capacity. | | | | | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | These babies are original, unmodified, and riveted. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | My dad has an '88 light 3/4-ton with 6-lug axles. That configuration came back at some point. | | |
