3 members (spanky, Joe H, UtahYork), 198 guests, and 3 robots.
Topics128,186
Posts1,057,307
Members48,468
Folks,
I have a pair of two-piece, split-rim artillery wheels, 16", 6-lug, that fit the old chevies (they were on my '47 sedan when I got them). I have never heard of GM using split artillery rims, only solid ones. I emailed the folks at Jim Carter's and they told me this is not a GM wheel (although it fits the GM 6-lug hub). Any ideas on what these wheels possibly came off of? Judging by what I've seen the solid arty wheels go for on ebay, I think they might fetch a few bucks, and I'd like to sell them so I can continue to pour money into my old chevies. Thanks for the input.
Tyler
1953 3600 Pickup
1946 Fleetline Aerosedan
1948 Hudson Commodore
I'm not sure, but I have three :mad: of the same. I'm curious to find out as well.
Your lack of preparation is not my emergency
those rims are unsafe.Many state inspection not aloud.split rims are history.Take them to the bone yard .I also have 4 of those rims on a early 55 3/4T
dan-pa
Split rims are not unsafe per se. Damaged or rusted out split rims are unsafe. I've never heard of them being "not aloud". Do you mean "not allowed"? I've never heard of any factory configuration not being allowed on an old vehicle.
But if you want to send them to a bone yard you can send them to mine.
thats funny I have never seen six hole wheels on 3/4 ton expt for mabe some realy old chevys (35-37?)
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
The first year Chev. made a 3/4-ton was 1937. The 3/4-tons shared the 6-bolt axles and drums with the 1/2-tons until 1946 when they got the heavier 8-bolt parts that we now associate with 3/4-tonners. The standard wheel on the '37-'42 3/4 was the 15 x 5-1/2" artillery wheel which is highly valued today since it looks good and will take a modern 15" radial tire. This 15" wheel was an option on the 1/2 tons. Heavy duty 3/4 tons in those years came with an odd looking 17" wheel. Some earlier Chev. cars came with a narrow 16" artillery wheel which has very little value. I have never seen a 16" split rim artillery wheel. Can you maybe post a picture of the wheel in question?
To be long remembered as he's cruising in
The Passing Lane
Is this wheel riveted or welded together?
Local welding shops used to weld the wider split rims on the customers orginal wheel centers to increase the load capacity.
These babies are original, unmodified, and riveted.
1953 3600 Pickup
My dad has an '88 light 3/4-ton with 6-lug axles. That configuration came back at some point.
1954 GMC De Luxe COE
