0 members (),
90
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 4 Junior Member | | Junior Member Joined: Mar 2005 Posts: 4 | WILL A 1987 CHEVY VAN FRONT SUSPENSION/DISC BRAKES SETUP TRANSPLANT INTO MY 1963 GMC PICKUP | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | From what I've gathered, it will with maybe the exception of a couple of bolt holes that will need to be drilled. Don't forget the master and the prop valve though, Scott | | | | | Joined: Mar 2005 Posts: 4 Junior Member | | Junior Member Joined: Mar 2005 Posts: 4 | I HAVE HEARD THE 1/2 TON TRUCK UP TO 87 WILL FIT, BUT THIS IS A VAN. JUST TRYING TO SEE IF THERE WOULD BE ANY DIFFERENCE. THANKS. | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Starting sometime in the 70's Chevy vans are a unit-body construction. I don't know if the IFS can be removed as a unit or not.
However, check the track width. Those vans are wider than the pickups and even if you can drop it off easily it may be way too wide for your '63.
Hey someone said recently that a '63 GMC had the torsion bar suspenion instead of the coils like a Chevy. Can you confirm or deny that?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2005 Posts: 4 Junior Member | | Junior Member Joined: Mar 2005 Posts: 4 | my 63 gmc has coil springs for front suspension. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | you could also get a disc brake conversion, or just buy kevlar brakes from www.praisedynobrake.com which I have on my truck and work well. Change the brake shoes and keep what you got is one solution. (and a lot less work) | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by stepat1: my 63 gmc has coil springs for front suspension. Thanks for answering that. I was surprised when someone said they were torsion bar, but not having ready access to a '63 GMC I couldn't check.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The van is much different from the pickup. It would be hard to use it for a swap. It is wider. The 60-62 were torsion bars. It was kind of a poor setup & is hard to get parts for now. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Hey step1, welcome to the bolt. Would you please hit the caps lock key so we don't have anyone having a S%*&%t fit because of the all caps.
Me I don't really care. There are way to many other things in life to worry about.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
