1 members (RLB),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 10 Junior Member | | Junior Member Joined: Oct 2004 Posts: 10 | I recently purchased a 1955 series 1, chevy half ton and it has a large hole in the top of the dash. It is located about center between the gauges. It appears to have been done at the factory or at least professionally done long ago. I cannot find any pictures of other trucks with this same hole or one with an accessory installed there. I'm new to old trucks and new to this board. I don't know yet how to post a picture here but I can e-mail a couple of pictures if it would help to see it. Thanks, Steve | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Sounds like a clock location. I know there are some guys out there with this optionthat can provide you wth pics. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | The clock has a housing and only needs some small holes. Your hole must have been owner cut. The only hole on top of the dash would be for the wiper switch.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | plastic jesus meltdown??? i don't recall seeing such a hole on top of the dash. probably a p.o. drilled the thing for who knows what. should be a not to bad fix--if the windshield is out. old trucks usually have a sturdy dshbouard. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The clock option requires three holes. A large one about the size of a quarter, and two small holes for attachment. I think the larger hole is so the clock light bulb can be changed with out removing the clock.
Hope this helps.
Lonnie | | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Cup holder  | | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | May be one of those flower holders like the new VW bugs have ... | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 |
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its an access hole to allow you to see what you are doing while trying to replace bulbs or remove or connect wires.
This is typically a dealer-installed option unless the modification was performed by someone else.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2004 Posts: 10 Junior Member | | Junior Member Joined: Oct 2004 Posts: 10 | Thanks everybody. I was planning to patch it but then had second thoughts. Figured first I should check with people who knew more about old trucks than I did. I appreciate your help. I'll be reading these boards regularly for information and will probably be asking a lot more questions before I'm through. Thanks Joy for posting the picture. Steve | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I contacted Doc Brown. That hole is the intake to the flux capacitor.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Clock hole boyz--that clock clears the housing. Gotta be a whole--change the light too. :p
Buzz'n Half Dozen
| | | | | Joined: May 2004 Posts: 96 Member | | Member Joined: May 2004 Posts: 96 | It's a cup holder (you need to cut it bigger for a Big Gulp). | | | | | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Just about the right size for one of those Keystone Light cans...
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Just went out and checked by truck. Large hole in the middle about the size of a half dollar with three small holes for attachment.
Just a note about the clock; it is on the shelf in the garage at this time. Works perfectly. It was made by the New Haven Clock and Watch Co. It is truely a large watch. It is mechanical of course, and will run 48 hours on a full winding.
When I first bought my 54, the clock was something I though I would sell off. But have come to like it as well as the visor.
Lonnie | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | That is one the holes where the money goes in
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Luke's answer is the best!! At least that's what my wife says. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | 1955 air conditioning. I see the vent louver is missing (they are VERY RARE) would of had a 2 3/4" duct hose that ran over to the cowl vent. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | A great place to mount a tach. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 |
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Any hole just big enough for your kid to put his finger in, or his hand or head, is so you can appreciate that life will never be back to normal until they are grown up and living on their own. | | |
