| | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | Anyone seen the phillips head screws that mount the door hinges to the jam? I have looked at all the parts stores I know of with no luck. I just need three of four. Thanks for the help! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Are these big flathead phillips screws? Early Jeeps use similar screws for the windshield hinges. I found some at a really big local Ace hardware store. They are really hard to find, I had to search quite a while. You may want to try a Grainger or tractor supply place if you can't find them at a regular fastener supplier.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Kevin - Check with McFadden-Dale in Corona if they don't have them no one does. Give them a call (951) 734-3620. They are just north of the freeway on Maple. Good Luck George | | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | George, I called, he has them in stainless. I will take a drive there tomorrow. Thanks for the tip!
I love this site!!! | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Any advice on removing them without destroying them?
I'm about pull mine out and would rather not have to find replacements. | | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | Why do you think that I need some? I think the best thing to do is to get a impact screw driver and maybe a little heat. You can get a cheap impact srew driver from Harbor Frieght. That is where I got mine. Good Luck! | | |
