0 members (), 85 guests, and 1 robot.
Topics128,049
Posts1,055,740
#170765 03/17/2005 7:37 PM
Anyone seen the phillips head screws that mount the door hinges to the jam? I have looked at all the parts stores I know of with no luck.
I just need three of four. Thanks for the help!
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
#170766 03/18/2005 10:28 AM
Are these big flathead phillips screws? Early Jeeps use similar screws for the windshield hinges. I found some at a really big local Ace hardware store. They are really hard to find, I had to search quite a while. You may want to try a Grainger or tractor supply place if you can't find them at a regular fastener supplier.
Paint & Body Shop moderator
#170767 03/18/2005 5:02 PM
Kevin - Check with McFadden-Dale in Corona if they don't have them no one does. Give them a call (951) 734-3620. They are just north of the freeway on Maple.
Good Luck
George
#170768 03/18/2005 8:02 PM
George, I called, he has them in stainless.
I will take a drive there tomorrow.
Thanks for the tip!
I love this site!!!
Regards, Kevin
#170769 03/19/2005 3:11 AM
I
I Offline
Any advice on removing them without destroying them?
I'm about pull mine out and would rather not have to find replacements.
#170770 03/19/2005 8:19 AM
Why do you think that I need some?
I think the best thing to do is to get a impact screw driver and maybe a little heat.
You can get a cheap impact srew driver from Harbor Frieght. That is where I got mine.
Good Luck!
Regards, Kevin
