3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#169995 01/20/2005 4:13 AM
Junior Member
Junior Member
My truck has no interior door lock knob. I am finally painting my truck and I am buying new door handles. LMC sells the handles with a non locking handle and a locking handle. Since i need both to lock that wouldnt do me much good. Does anyone know of anyone that sells door handles that have both locks or an idea on how to make interior door lock knobs? Thanks for all the help.
#169996 01/20/2005 4:15 AM
To lock the doors from the inside of a 64, you just push the inner door handle the opposite way you would to open it. No inner lock knobs are needed,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#169997 01/20/2005 5:00 AM
The Custom cab trucks had outside keylocks on both sides, you can add them easily. Still have to use the key, but you can lock both doors from outside w/o pushing inner handle. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#169998 01/23/2005 5:01 AM
Junior Member
Junior Member
i ordered new door handles from lmc. They say one is ready for a locking cylinder. the other has a non locking cylinder already installed. Anyway to remove the non locking cylinder from that and put in a locking one? Is it hard? Havent taken one apart yet but i will be receiving a door handle set and 2 locking cylinders keyed alike and i need a way to take the non locking cylinder out.
#169999 01/25/2005 1:06 AM
To remove your non-locking button or locking button, push in the round, flat piece from the back of the handle and use a small screwdriver to flip out the snap-ring. The flat washer and a spring will come out and then the button, locking or non-locking. If it hasn't deterierated there should be an "O" ring around the button. This is just a cushion tor the button. The new set should have new "O" Rings. By the way, you will need to have the handles removed from the door for this operation. There will be two screws holding on the handle from the inside of the door. (or they may be two small bolts - 7/16 head) Quite simple when you take one apart.
Truck Tinker
