| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | My truck has no interior door lock knob. I am finally painting my truck and I am buying new door handles. LMC sells the handles with a non locking handle and a locking handle. Since i need both to lock that wouldnt do me much good. Does anyone know of anyone that sells door handles that have both locks or an idea on how to make interior door lock knobs? Thanks for all the help. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | To lock the doors from the inside of a 64, you just push the inner door handle the opposite way you would to open it. No inner lock knobs are needed, Scott | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The Custom cab trucks had outside keylocks on both sides, you can add them easily. Still have to use the key, but you can lock both doors from outside w/o pushing inner handle. Brian | | | | | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | i ordered new door handles from lmc. They say one is ready for a locking cylinder. the other has a non locking cylinder already installed. Anyway to remove the non locking cylinder from that and put in a locking one? Is it hard? Havent taken one apart yet but i will be receiving a door handle set and 2 locking cylinders keyed alike and i need a way to take the non locking cylinder out. | | | | | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | To remove your non-locking button or locking button, push in the round, flat piece from the back of the handle and use a small screwdriver to flip out the snap-ring. The flat washer and a spring will come out and then the button, locking or non-locking. If it hasn't deterierated there should be an "O" ring around the button. This is just a cushion tor the button. The new set should have new "O" Rings. By the way, you will need to have the handles removed from the door for this operation. There will be two screws holding on the handle from the inside of the door. (or they may be two small bolts - 7/16 head) Quite simple when you take one apart.
Truck Tinker | | |
