7 members (Wrenchman, Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, 1 invisible), 52 guests, and 2 robots.
Topics128,089
Posts1,056,009
Members48,430
#169814 04/15/2005 4:18 AM
I invented a "CLUTCH DISENGAGER" after getting stuck in gear with the column shift on my 1966 C-10. I cut a 2x4 to a size that would depress the clutch pedal when placed lenghwise between the seat and pedal. This will allow you to free up the jammed linkage without involving another person. I don't need to use it often, but it can be a life saver when linkage gets jammed.
So, if you have one of these three on the tree rigs, it is a good idea to make a "CLUTCH DISENGAGER". Just make sure that you mark it as one, so that the cops will not accuse you of carrying a weapon in your vehicle.
Maybe I should patent this, and make a million bucks.
Doug 57
#169815 04/15/2005 4:24 AM
but be sure the hand brake is engaged! all the trucks I've had that jammed up like that always did it on hills! eek
actually the easier thing is to rebuild the shift box on the column and get rid of the slop in the linkage so it don't jam grin
#169816 04/15/2005 4:30 AM
That's right Bill. It is a good idea to set the parking brake. I had a 1970 Pontiac that had a "PARKING BRICK". The parking brake did not work any more.
I replace the bushings in the linkage, and that has stopped the problem most of the time.
Doug 57.
#169817 04/15/2005 1:55 PM
I couldn't take it & fixed the column, welding up the shift "ears" fixed it for the next 40 yrs. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#169818 04/15/2005 2:14 PM
Found my problem was some bent linkage..jammed only when there was an ambulance bearing down and i was at a stoplight...they just couldn't figure out why i wasn't getting out of the way..amazing how 150lbs can push an AD full of 2x4's through an intersection so fast
#169819 04/15/2005 5:19 PM
Brian, explain what you mean about welding up the shift ears.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
#169820 04/15/2005 7:36 PM
Ralph - he's no doubt talkin about the ears on the forks inside the box on the column - not a great pic, but you can sorta see the notches should be pretty square, and with wear, if the open ends get rounded, sloppy shifting will allow the pawl to jam between the 2 forks - jamming can happen easier if the finger/pawl piece is worn too - keep this box packed w/ grease - also need to make sure the hard rubber shim bushings aren't sloppy, both at that box, and down at the trans levers - wear and sloppy parts are always the problem when the column shifter starts lockin up
