1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I invented a "CLUTCH DISENGAGER" after getting stuck in gear with the column shift on my 1966 C-10. I cut a 2x4 to a size that would depress the clutch pedal when placed lenghwise between the seat and pedal. This will allow you to free up the jammed linkage without involving another person. I don't need to use it often, but it can be a life saver when linkage gets jammed.
So, if you have one of these three on the tree rigs, it is a good idea to make a "CLUTCH DISENGAGER". Just make sure that you mark it as one, so that the cops will not accuse you of carrying a weapon in your vehicle.
Maybe I should patent this, and make a million bucks.
Doug 57 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | but be sure the hand brake is engaged! all the trucks I've had that jammed up like that always did it on hills! actually the easier thing is to rebuild the shift box on the column and get rid of the slop in the linkage so it don't jam Bill | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | That's right Bill. It is a good idea to set the parking brake. I had a 1970 Pontiac that had a "PARKING BRICK". The parking brake did not work any more.
I replace the bushings in the linkage, and that has stopped the problem most of the time.
Doug 57. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I couldn't take it & fixed the column, welding up the shift "ears" fixed it for the next 40 yrs. Brian | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Found my problem was some bent linkage..jammed only when there was an ambulance bearing down and i was at a stoplight...they just couldn't figure out why i wasn't getting out of the way..amazing how 150lbs can push an AD full of 2x4's through an intersection so fast | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Brian, explain what you mean about welding up the shift ears. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ralph - he's no doubt talkin about the ears on the forks inside the box on the column - not a great pic, but you can sorta see the notches should be pretty square, and with wear, if the open ends get rounded, sloppy shifting will allow the pawl to jam between the 2 forks - jamming can happen easier if the finger/pawl piece is worn too - keep this box packed w/ grease - also need to make sure the hard rubber shim bushings aren't sloppy, both at that box, and down at the trans levers - wear and sloppy parts are always the problem when the column shifter starts lockin up Bill | | |
