2 members (Ole49GMC, Hush),
74
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | OK, I have a question... When I go to mount my cab back onto the frame, what kit do I need to buy? American has two kits one with just the wooden blocks and some bolts... http://www.americanclassic.com/images/cb206.gif And one with wooden blocks and bolts with rubber and springs...??? http://www.americanclassic.com/images/cb850.gif Since I didn't dismantle the cab from the frame myself I don't know what to buy... Any help out there??? | | | | | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | I could be wrong, but I thought the wood blocks, rubber pads and bolt were for the bed, not the cab.
1948 3600 thriftmaster
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Kevin - Your 40 is going to be like my 46. you need the bolts, wood blocks, rubber pads and springs. Most of the vendors have a kit for the cab mounts. Also check the tech tips there is a good artical on the cab mounts for the 41-46. Good Luck George | | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | George, That's the ticket! I should have checked the Tech Tip first. I now know I need all the little parts... rubber, springs, bolts, washers, bushings, etc. Thanks to Randy for the sketches, that helps alot! | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 |
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Rusty, thanks for the tip - I was thinking about making non-wood blocks in either rubber or polyurethane. | | |
