7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible), 56 guests, and 3 robots.
Topics128,176
Posts1,057,122
Members48,463
OK, I have a question...
When I go to mount my cab back onto the frame, what kit do I need to buy?
American has two kits one with just the wooden blocks and some bolts...
http://www.americanclassic.com/images/cb206.gif
And one with wooden blocks and bolts with rubber and springs...???
http://www.americanclassic.com/images/cb850.gif
Since I didn't dismantle the cab from the frame myself I don't know what to buy...
Any help out there???
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
I could be wrong, but I thought the wood blocks, rubber pads and bolt were for the bed, not the cab.
1948 3600 thriftmaster
Kevin - Your 40 is going to be like my 46. you need the bolts, wood blocks, rubber pads and springs. Most of the vendors have a kit for the cab mounts. Also check the tech tips there is a good artical on the cab mounts for the 41-46.
Good Luck
George
George, That's the ticket! I should have checked the Tech Tip first.
I now know I need all the little parts... rubber, springs, bolts, washers, bushings, etc.
Thanks to Randy for the sketches, that helps alot!
Regards, Kevin
I used hockey pucks.
Another quality post.
Real Trucks Rattle
Rusty, thanks for the tip - I was thinking about making non-wood blocks in either rubber or polyurethane.
1954 GMC De Luxe COE
