5 members (dunfire, 2-Ton, jmoore, TUTS 59, WICruiser), 173 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#167263 03/04/2005 12:47 AM
Hi all, The vacuum wipers on my 48 daily driver have never worked and I am going to tear them down and get them going soon. In the mean time, they get enough vacuum to slowly rise to about the middle of the window as I am driving. If I push the switch towards the window (counter-clock-wise)they will go back to park. My question is, where is the off position for these things? I hear a small pssst when I turn the switch c.w. Thanks in advance.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
#167264 03/04/2005 2:57 PM
Well I can't answer the "off position" but once you get the motor out you should see a couple of small vent holes near the vacuum tube connection. Make note of where these holes are. You will want to add a few drops of light oil in these holes while running the wippers. This of course is after having rebuilt the motor. If you search I am sure you will find a couple of post on rebuilding your wipper motor.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#167265 03/04/2005 3:05 PM
the off position is to the right or turning it clock wise. i took mine apart a couple of weeks ago and cleaned it a put vaseline on vane to lubricate it. don't use lithium or any thing else they are to heavy. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#167266 03/04/2005 4:09 PM
I squirted light 3-in-1 oil in all the openings of mine and worked the lever back and forth. That and the dual stage fuel pump for extra vacuum have worked for me.
#167267 03/04/2005 6:45 PM
8
8 Offline
I tried lubing mine with vasoline. It worked great, as long as the temp was 65 and above. Below that, the vasoline got thick and kept the vane from moving properly. If you really want to get the job done well, do a search and check out Ficken Wiper Service . IMHO that really looks like the way to go.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#167268 03/04/2005 7:28 PM
Thanks for all the reply's guys. We have had so much rain this year, and I have been driving without wipers and I think I better get them going. I may overhaul one of the ones out of my other trucks and then swap. I have read several posts on working on these motors, and think I can handle that, but I have been needing to do an overhaul on my 235 anyway and assumed I would take care of this stuff, when it was parked for a motor swap. I was just curious if I was leaving the switch on during normal driving and didnt want to hurt anything. Thanks again and pass the rain-ex.
Ralph
48 Chevy 3600 w/235
#167269 03/04/2005 8:31 PM
My original wiper motor works just fine. The park position is to turn the knob on the dash fully counterclockwise, and clockwise is on high. In between varies the speed of the wipers. When you turn it all the way counterclockwise the wipers park from wherever they were when you twisted the knob.
You will not hurt the truck or the wiper motor by leaving it on when the wipers are stuck. It does not pull enough vacuum to affect the engine and the wiper motor is a pretty tough little mechanism. They work pretty well when rebuilt.
Paint & Body Shop moderator
#167270 03/05/2005 4:51 PM
Oldtmy48 www.wiperman.com ficken wiper service w. babylon ny heard alot about this guy and nothing but GOOD he also happens to be about 4mi from me on L.I. you prob can send him one or two of your parts truck wiper cores to avoid taking your dialy driver apart till you have the rebuilt thats what i.m doing wink regards in advance design Steve Sr.
#167271 03/05/2005 9:16 PM
Riding in the Passing Lane
If it,s a daily driver why not put in an electric conversion. They are easy to install & work slick. smile
1972 Chevy c10 Cheyenne Super
#167272 03/07/2005 2:23 PM
8
8 Offline
I installed an electric motor, and it does work slick, but...It took a ton of tweaking to get the sweep and park position right. If there is any play at the end of your transmission arm, be prepared for lots of tedious work.
-Tim
