0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hi all, The vacuum wipers on my 48 daily driver have never worked and I am going to tear them down and get them going soon. In the mean time, they get enough vacuum to slowly rise to about the middle of the window as I am driving. If I push the switch towards the window (counter-clock-wise)they will go back to park. My question is, where is the off position for these things? I hear a small pssst when I turn the switch c.w. Thanks in advance. Ralph | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Well I can't answer the "off position" but once you get the motor out you should see a couple of small vent holes near the vacuum tube connection. Make note of where these holes are. You will want to add a few drops of light oil in these holes while running the wippers. This of course is after having rebuilt the motor. If you search I am sure you will find a couple of post on rebuilding your wipper motor.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | the off position is to the right or turning it clock wise. i took mine apart a couple of weeks ago and cleaned it a put vaseline on vane to lubricate it. don't use lithium or any thing else they are to heavy. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I squirted light 3-in-1 oil in all the openings of mine and worked the lever back and forth. That and the dual stage fuel pump for extra vacuum have worked for me. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I tried lubing mine with vasoline. It worked great, as long as the temp was 65 and above. Below that, the vasoline got thick and kept the vane from moving properly. If you really want to get the job done well, do a search and check out Ficken Wiper Service . IMHO that really looks like the way to go.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Thanks for all the reply's guys. We have had so much rain this year, and I have been driving without wipers and I think I better get them going. I may overhaul one of the ones out of my other trucks and then swap. I have read several posts on working on these motors, and think I can handle that, but I have been needing to do an overhaul on my 235 anyway and assumed I would take care of this stuff, when it was parked for a motor swap. I was just curious if I was leaving the switch on during normal driving and didnt want to hurt anything. Thanks again and pass the rain-ex. Ralph | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My original wiper motor works just fine. The park position is to turn the knob on the dash fully counterclockwise, and clockwise is on high. In between varies the speed of the wipers. When you turn it all the way counterclockwise the wipers park from wherever they were when you twisted the knob.
You will not hurt the truck or the wiper motor by leaving it on when the wipers are stuck. It does not pull enough vacuum to affect the engine and the wiper motor is a pretty tough little mechanism. They work pretty well when rebuilt.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Oldtmy48 www.wiperman.com ficken wiper service w. babylon ny heard alot about this guy and nothing but GOOD he also happens to be about 4mi from me on L.I. you prob can send him one or two of your parts truck wiper cores to avoid taking your dialy driver apart till you have the rebuilt thats what i.m doing  regards in advance design Steve Sr. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it,s a daily driver why not put in an electric conversion. They are easy to install & work slick.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I installed an electric motor, and it does work slick, but...It took a ton of tweaking to get the sweep and park position right. If there is any play at the end of your transmission arm, be prepared for lots of tedious work.
