| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 95 | Seems that several years ago that a "new" odometer wheel was available on the reproduction market for about 10 bucks. I know the wheel stickers are out there, but does anyone know where or how I can get a new odometer - or at least set mine back to 00000 as I drop in my rebuilt engine???? I don't know of any vendors listing these things anymore
J.D. Jordan
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If your only issue is recording the miles since the rebuild, you'll probably be better off not messing with the odometer reading. Just make a note of the reading for reference.
Most titles have the mileage reading on them. If you set the reading back and someday try to sell the vehicle, especially with a lower mileage number than when you titled it, getting the title transferred could be an issue. Also many collectors place a lot of value on odometer readings being correct. You could lower the value of your ride by messing with the reading.
If you're bound and determined to change it any speedo rebuild shop can set it to any number you wish.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | dublenaught: its personal preference. No matter what the old mileage says you'll never know if its 100 thousand or two hundred thousand. So, when I do mine I always set speedo to zero....after all, it is a NEW vehicle isn't it? I see you are in Charlotte, no far from me. If you need resto work done on it there is D&M Restorations in Greenville, N.C. thats does a jam up job. I was just over there Monday and picked up a 57 chevy temp guage. Looks great and Mike is very knowledgeable about a lot of little things that help in unusualy situations. Give him a call at 864-421-9959. Tell Mike that Alvin said to give you a discount!! | | | | | Joined: Jun 2007 Posts: 95 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 95 | Great; thanks for the help guys. I'll likely never sell the truck (never say never though)since It was my Grt. Grandfathers (I'm second owner).....thanks for the link to D&M....although by the area code, I'm assuming they are in Greenville South...
J.D. Jordan
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | dublenaught: your right. It is Greenville S.C. However I did work in Greenville, N.C. for a spell.....and from Charlotte it is still closer than the one in N.C.!! Whew, that was a long drive to be doing it regularly! | | |
