1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#166323 06/25/2007 11:37 PM
Anyone know of a way to remove vinyl that has been glued down with contact cement? Thanx
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#166324 06/25/2007 11:56 PM
Ex Hall Monitor
Ex Hall Monitor
You might try acetone but it's nasty stuff. Try it on a small spot first.
#166325 06/26/2007 12:03 AM
Lacquer thinner?
#166326 06/26/2007 3:16 AM
Used to use plain old mineral spirits in a spray bottle to remove formica that had been glued down with contact cement. This was mainly on partical board or plywood but the M/S was the least offensive stuff. It softens the glue....could let it soak into the surface overnight, recoat with contact cement and re-apply new mica.
M/S will also remove over-glue....the C/C balls up and rubs right off.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#166327 06/26/2007 3:17 AM
Look at a hardware,woodworkers supply, or building supply store for "contact cement thinner and cleaner"
Harold Wilson
41 Chevy 3/4 Ton
#166328 06/26/2007 1:25 PM
I have to change out the felt pads on the finishing heads on our wide belt sanders the felt is glued on with contact cement ...well my Maint. crew does the work I just supervise ...and we have tried acetone & laquer thinner ....and found Regular Ol paint thiner / Mineral Spirits works the best by far , as Dave stated. soak it let it set a while an it will soften the contact cement for easy removal .Hope this helps
1952 Chevy Shortbed
Photos in Photobucket
#166329 06/26/2007 2:33 PM
I'll bet it works just as good as the 3m #8984 "General Purpose Adhesive Cleaner" that I paid ten bucks a quart for. It does the same thing with the freshly applied weather strip adhesive, just simply balls it up and won't touch the old stuff that was on the doors.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#166330 06/26/2007 2:41 PM
Ex Hall Monitor
Ex Hall Monitor
Looks like mineral spirits is the stuff to use then. I'll file that bit of info into the cranial trivia file. grin
Moderated by  ndkid275, Phak1
