1 members (wvstovebolt),
31
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Anyone know of a way to remove vinyl that has been glued down with contact cement? Thanx
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You might try acetone but it's nasty stuff. Try it on a small spot first.
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Used to use plain old mineral spirits in a spray bottle to remove formica that had been glued down with contact cement. This was mainly on partical board or plywood but the M/S was the least offensive stuff. It softens the glue....could let it soak into the surface overnight, recoat with contact cement and re-apply new mica.
M/S will also remove over-glue....the C/C balls up and rubs right off.
Dave | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Look at a hardware,woodworkers supply, or building supply store for "contact cement thinner and cleaner"
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I have to change out the felt pads on the finishing heads on our wide belt sanders the felt is glued on with contact cement ...well my Maint. crew does the work I just supervise ...and we have tried acetone & laquer thinner ....and found Regular Ol paint thiner / Mineral Spirits works the best by far , as Dave stated. soak it let it set a while an it will soften the contact cement for easy removal .Hope this helps | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'll bet it works just as good as the 3m #8984 "General Purpose Adhesive Cleaner" that I paid ten bucks a quart for. It does the same thing with the freshly applied weather strip adhesive, just simply balls it up and won't touch the old stuff that was on the doors. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Looks like mineral spirits is the stuff to use then. I'll file that bit of info into the cranial trivia file.
