0 members (), 83 guests, and 0 robots.
Topics128,108
Posts1,056,566
Members48,448
#166318 06/25/2007 5:25 PM
Can anyone post a picture of a rearveiw mirror installed on a 1950 3100. I think I know where to put it but I want to be sure.
Tom
Tommy631, I don't have a picture but my 48' and 53's were mounted in the center windshield strip threaded into a hole in the strip about 2 1/2 " from the top. Hope this helps!
Mike
Thanks. Thats what I needed to know.
I don't have a picture either, but on my 52 the rearview mirror mounts to a bracket held to the interior divider bar trim with a bolt that retains the outer divider bar trim. My 47 to 54 assembly manual shows 5 holes in the divider bar. Perhaps for the earlier models to thread a mirror into. In the examples that I have seen personally it looks like the quick fix was to gouge a hole in the windshield gasket and screw the mirror into a nut behind the divider bar, Jimmie.
#166322 07/09/2007 12:32 AM
I think that there are two methods. One is to use one of the trim screws that go through the center bar and the other is to drill and tap the center bar. There is a plug of steel near the top of the divider bar that is hidden by the trim strip. I believe this is what you drill and tap.
1951 1 Ton Completed
I am trying to install the rearview mirror on my '50 3100 truck and did a search to come up with this thread.
My question is how does the mirror mount? I have a hole in the divider bar and a hole in the retainer bar on the inside of the divider bar. Is there a bolt that must go in that hole before the windshield gasket is installed?
Does anyone have a picture? I have the assembly manual and cannot find anything showing how the mirror is installed.
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
Mine just screws into a threaded hole in the molding on the divider bar. You should have a threaded shaft on the mirror with a stop nut on it. I don't know anything about a hole in the divider bar.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Isn't there a bracket that mounts to the dividing bar and then the mirror mounts to the bracket?
Mirror Bracket
Webshot Photos
Not on my 49. Just a tapped hole in the divider bar. There is a post on the mirror with a threaded end and a lock nut.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Mirror Bracket
That's the set up I've got on my '50, there's a corresponding hole in the inner 'bar' that the threaded end of the mirror goes into behind the mounting bracket.
More pix on Flickr.
Moderated by  ndkid275, Phak1
