2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | Things are fast paced now, only waited 2 months for the vent window glass to arrive. Now that it is here I'm trying to install the glass into the frame using the "glass setting tape". It is not going well as I have the rubber mallet pounding quite hard against the edge of the glass and its not entering the frame. Just the top and bottom are starting to enter the frame....it needs to side in more towards the vertical portion of the frame.
Just had a thought, am I installing the setting tape backwards? I'm putting the rubber side against the glass and the fabric side against the frame. Is this correct?
Should I forget the setting tape and use some kind of caulk? If so, what?
Thanks | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Don't know if this will help, but I did all the windows in my 54....used Classic American parts replacement vent windows and setting tape. They said to use the tape as it came off the roll....the rubber on the glass, fabric towards the frame. Cut off ample tape, SOAK IT for 10 minutes in motor oil, using the glass like a shoehorn, press in the glass to seat it.
A couple things I discovered on my own...the CAP glass was a bit thinner than the original (I got the tinted stuff)...you're best to have the wing window mounted in the frame so you can close it up and make sure the back vertical edge fits properly against the vertical seal in the frame. I moved it around until the glass was properly positioned and locked the latch down....next day the glass was tight. Trimmed the excess tape and I was good to go.
My replacement glass is .235 thick and the setting tape .045 thick. You didn't mention if you were soaking the tape but IT IS A MUST. Makes a big mess but my windows are secure and fit properly. Hope this is some help!
Dave | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | Thanks for the great pics and clear step by step Houston54. I add your vents to my growing list of great links!  | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | Houston54 You may have missed your calling....what a professional writeup and pics. After my post, I did a search on "vent window" (my first search was on "wing window") and found some very good information. So I did one vent window using what infro I could find. Today, I will use your description and expect far better results than on my first attempt. I'm concerned about my first attempt as I have pounded the window seemingly as far as it will go and there is about 3/16" reveal. Fitting it into the new weatherstripping will show what my next step should be. Heres hoping it will be OK.
Thanks so much for the "education". | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Good luck with it. Hope if helps you out. | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | That is a great write up. Should be added to the Tech Tips and added to hotrodder forum's wiki. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Here is a tip i used to remove the vent glass from the frame. I picked up a heat gun from Home Depot for 10 bucks in the paint dept. The same gun in the tool section was 19.99. Anyway I turned the gun on high and played the heat around the frame, inside and out. In just a few moments the tar softened and I just pulled the old glass out. Useing the gun and a screwdriver in tandem I scooped out most of the remaining setting tape. A few minutes with a solvent and the frame was clean as a whistle. | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | Thanks again for the help, I've completed the both vent windows and installed them into the doors. They look great and fit nicely. | | | | | Joined: Dec 2005 Posts: 36 New Guy | | New Guy Joined: Dec 2005 Posts: 36 | I need some help on installation of new wing windows. There is a post by anonymous(houston54) that lists a url website detailing how he did his. I cannot open it. Each time I try it tells me the file name cannot be found. Can someone help me? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | blkhrn, one way would be to click on their names and send him a PM with your request. I feel sure he will be glad to help you. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Link is gone from my end also, must have closed his album to us. I’m gonna be doin’ my glass and rubber in the ’54 and since I like to make up “special tools” I think I’m gonna give one of these a try; http://www.pbase.com/dennygraham/image/123683003/large Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | | | |
