5 members (Hanks custodian, mick53, moparguy, CATMAN, joe apple), 86 guests, and 2 robots.
Topics128,151
Posts1,056,989
Members48,460
I now have a good handle on how to deaden "ringing" doors and other noise makers. BTY thanks to all responders, especially "Restoman57". On to other things. Heat suppression or attenuation of heat from outside the passenger compartment. What do you guys use in the doors, roof and most important the firewall to "kill" the heat. Thanks
Z
Z Offline
fatmat.
1946 Chevy Pickip
dynamat i guess it's like the peel and stick some guys refer to here. it kills the 'tin' sound.
http://www.dynamat.com/
i also use the two sided foil/jute combo as insulation and a carpet on top.
Jim & Caroline
Here's what I did:
Click Here
It worked great!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Apprentice
Apprentice
Fellow Stovebolters, I am working on getting all of the information together for everyone contacting me. I have had numerous inquiries about the heat shield material. I do personally use this in our shop when stripping a vehicle out and apply for sound deadening and to reflect as much heat back out of the vehicle as possible. The material is available single or dual sided aluminum faced with an approx. 5/16" sound deadner applied.
[Portions Edited to Comply with Stovebolt Policies -- no selling allowed in posts]
Thanks Mr. Horvath grin you speak language even I can understand. I plan to use it all in my panel. Man, that thing should ride quiet as a....mmmmmm, maybe quiet as a hearse!!!
It sure makes a difference! And that difference sure makes you smile!
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
Got my floor (firewall) insulation material from Moore Power www.moorepower.com in Waverly, NE. The best investment I ever made--bar none. Almost zero heat transfer through the material--you can put a blow torch on one side and feel nothing on the other side. The stuff is used in stock cars (about 1/8 in. thick, cut with scissors). I went from burning the #@&% out of my right foot within 30 miles from home and using the cruise control just to keep my foot from being medium rare to "AHH!, let's go for a long ride, honey!"
BTW, I also used peel 'n seal in the doors, floor, and roof for insulation and sound proofing.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
Moderated by  ndkid275, Phak1
