| | | Forums66 Topics128,151 Posts1,056,994 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I now have a good handle on how to deaden "ringing" doors and other noise makers. BTY thanks to all responders, especially "Restoman57". On to other things. Heat suppression or attenuation of heat from outside the passenger compartment. What do you guys use in the doors, roof and most important the firewall to "kill" the heat. Thanks
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 |
1946 Chevy Pickip
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | dynamat i guess it's like the peel and stick some guys refer to here. it kills the 'tin' sound. http://www.dynamat.com/ i also use the two sided foil/jute combo as insulation and a carpet on top.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Here's what I did: Click Here It worked great!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2006 Posts: 24 Apprentice | | Apprentice Joined: Feb 2006 Posts: 24 | Fellow Stovebolters, I am working on getting all of the information together for everyone contacting me. I have had numerous inquiries about the heat shield material. I do personally use this in our shop when stripping a vehicle out and apply for sound deadening and to reflect as much heat back out of the vehicle as possible. The material is available single or dual sided aluminum faced with an approx. 5/16" sound deadner applied. [Portions Edited to Comply with Stovebolt Policies -- no selling allowed in posts] | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks Mr. Horvath  you speak language even I can understand. I plan to use it all in my panel. Man, that thing should ride quiet as a....mmmmmm, maybe quiet as a hearse!!! | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | It sure makes a difference! And that difference sure makes you smile!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Got my floor (firewall) insulation material from Moore Power www.moorepower.com in Waverly, NE. The best investment I ever made--bar none. Almost zero heat transfer through the material--you can put a blow torch on one side and feel nothing on the other side. The stuff is used in stock cars (about 1/8 in. thick, cut with scissors). I went from burning the #@&% out of my right foot within 30 miles from home and using the cruise control just to keep my foot from being medium rare to "AHH!, let's go for a long ride, honey!" BTW, I also used peel 'n seal in the doors, floor, and roof for insulation and sound proofing. | | |
