| | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16509 03/23/2004 2:41 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Hay, I just purchased a 1952 Chevy 1/2 ton with the number on the motor F206H can anyone tell the year of the motor.
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#16510 03/23/2004 3:45 AM | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | uhm. What is in it currently? A inline 6? v-6? v-8? to the right of the distributor on the block... if I recall right, is where the casting number for the block is... for the inline 6 - 235 anyhoo...(the '57 model anyhow) ... -W | | |
#16511 03/24/2004 1:53 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Yes it is an in-line 6 the casting number to the right of the distributor. Is 3837004.
Any info would help. Owlybear
#16512 03/24/2004 2:26 AM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | According to the casting numbers posted on Inliners.org 3837004 is a 55-57 235.
shoeless | | |
#16513 03/24/2004 2:43 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If true that would a great full pressure insert bearing motor.
54 3100 with 235 62 flatbed dump C60 with 261
#16514 03/24/2004 5:50 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Owlybear,
In the range of 1955-1957, the "F 206 H" engine serial number indicates a 1957 235 engine built in Flint, MI with a manual transmission (built on February 6).
Tim | | |
#16515 03/25/2004 1:33 AM | Joined: May 2002 Posts: 36 Junior Member | | Junior Member Joined: May 2002 Posts: 36 | Thank you guys for all the Info, this helps alot.
