4 members (Gdads51, greenie-reddy, Shade Baby, Jon G), 74 guests, and 1 robot.
Topics128,264
Posts1,058,352
Members48,485
#16509 03/23/2004 2:41 AM
Junior Member
Junior Member
Hay, I just purchased a 1952 Chevy 1/2 ton with the number on the motor F206H can anyone tell the year of the motor.
I've never been lost just confused for a month or two. 1950 & 1952 chev. 1998 Chev 4x4.
#16510 03/23/2004 3:45 AM
Socket Breaker
Socket Breaker
uhm.
What is in it currently? A inline 6? v-6? v-8?
smile
to the right of the distributor on the block... if I recall right, is where the casting number for the block is... for the inline 6 - 235 anyhoo...(the '57 model anyhow) ...
-W
#16511 03/24/2004 1:53 AM
Junior Member
Junior Member
Yes it is an in-line 6 the casting number to the right of the distributor. Is 3837004.
Any info would help.
Owlybear
#16512 03/24/2004 2:26 AM
According to the casting numbers posted on Inliners.org 3837004 is a 55-57 235.
shoeless
#16513 03/24/2004 2:43 AM
If true that would a great full pressure insert bearing motor.
54 3100 with 235
62 flatbed dump C60 with 261
#16514 03/24/2004 5:50 PM
Owlybear,
In the range of 1955-1957, the "F 206 H" engine serial number indicates a 1957 235 engine built in Flint, MI with a manual transmission (built on February 6).
Tim
#16515 03/25/2004 1:33 AM
Junior Member
Junior Member
Thank you guys for all the Info, this helps alot.
