3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | i have the seat frame, springs and adjustors for my seat, i know the seat back slides into the slots on the seat frame, an then screws to the top rail.
but how dose the bottom attach to the seat frame? would have thought it bolted to the adjustors but i dont think so...dose it just sit in the rails? ???????? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | on my 54 you slide the back in then push down on the front to latch it in place. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Mine seat goes the other way front in first and back last . On the front are to u clips that slide on to the frame this prevents the seat from moving forward. You slide the seat onto the frame then push the rear in, its snug and you have to give it a good push but it works. Peter | | | | | Joined: Jun 2006 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 20 | I agree w/ Petmil, the seat on my '49 3100 goes in the same way, 2 U clips in the front and then a snug push in the back keeps it all good. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i'm w/ we B my 51 bottom fits in, back slides in b-low the top cushion and has two (or3) short curved hooks that after you push back a little thaey hook around the front bottom frame tube. HINT::: HINT:::  in an AD cab if you want MORE storage room in the cab, cut away the front floor skirting. i left about a 12'' wide riser in the middle. which means i cut/sawed (skilsaw) two pieces right under the two riders legs, that's about 18'' wide, down to the floor. this allows you to gain access under the seat w/out lifting the bottom seat up. IT'S very convienent
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | ok if it latchs to the ft and the back cushion helps hold it on, how dose the rails raise and lower the seat? thanks | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | The adjustable rails bolt to the seat risers back by the cab mount bolts behind the riser and then to the platforms in the front corners of the riser.
The seat frame bolts to the rails.
The Bottom Cushion is held in with clips and can lift out. Some people put a hinge in the bottom to open it and more easily use the base as a storage compartment.
The Back Cushion clips to the bottom (tabs in slots) and clamps with screws to the top frame.
| | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | THANKS NM51!!!! i was scratching my head for awhile over that one. mine was missing the seat and i got a complete one with frame from my buddy who had already removed it before i saw how it was installed... works great now man pulled forward will shoot you into the roof... must have been for midgets:) | | | | | Joined: Sep 2006 Posts: 1 Junior Member | | Junior Member Joined: Sep 2006 Posts: 1 | I have a 1966 chevy c 10 delivery panel.It has a small bench with a bucket seat in the front that flips forward to get to the rear larger bench seat.this little bucket has no brackets or mounting hardware,so i don't know how it mounts.Does anyone have a picture or any advice were to get such a thing.What I don't have I can make. | | |
