1 members (JW51),
186
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I was just looking at all the options to reinsulate/redo the floor of my truck.
Would it be better to get the stuff from Classic Truck Parts, Inc. (old Chevy Duty) which would be the sound deading rubber mat, jute, and floor mat. Or use B-Quiet extreme and Quality Heat Shield or The Insulator by Cascade?
If both of these avenues would give the same end result. Or close to the same end result. It would be easier with Classic products since they are precut.
Finally, is the rubber mat the same at all vendors? American Classics and Classic Truck price theirs at $85-89. Where LMC prices theirs at $109. Does anyone know if they are the same product or is one a heavy duty and better product?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Dennis; I bought the jute and rubber floor mat for my '49 from one of the repop sellers. Can't remember who but probably Chevy Duty. Fits very well and the holes were all in the right places. Also bought the rubber inside firewall mat with jute backing to finish it off. Also fit fairly well although it was a little short where the floor mat and the firewall mat met. Only problem with the firewall mat is you need to remove everything off the firewall inside to mount the mat. Could have been a 1" longer to allow some tuck-in. All in all, I'm happy with it. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Got one from American Classic..fit nice and good quality. Bought lots of stuff from them on my 37 and it has held up very well. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I have peal n seal under my rubber mats in my 59 and my 72. I also have jute like double foil insulation I am going to add under the rubber mat in my 72 and on the firewall to see if it will add extra quiet to the cab. I have the 1/8 polypropolene on the 59 and it was cut almost perfect and is very durable. I have a thinner one for the 72 but its also cut exactly right. Makes for good washing out of bottle, hamburger wrappers, dirt, mud, effluvia with the old garden hose!  | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | I agree with arnswine, peal-n-seal firs, then whatever you want next. Keeps heat out and help with sound proofing the cab. http://community.webshots.com/user/46metal | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I did the peal and stick and the jute with aluminum foil under the rubber mat. Nice.
But I had to cut out the jute stuff in the middle at the hump so the gas peddle would work.
Thanks to all.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | check w/ an auto parts store, .... aka (FLAPS) they may have it cheaper and local, in bulk and u cut. i used a two sided foil type w/ jute inside and an indoor/outdoor low nap carpet over top.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I used a foam carpet pad that was backed with a fibreglass type of material I bought from Maynards. contact cement it down in any size pieces. quiet, cheap, easy, and it has been there 2 years now. | | |
