0 members (),
192
0
Mod | | | Forums66 Topics128,089 Posts1,056,143 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I have my door lock out and I see there is a 4 digit number on it. Does anyone know if there is a source for keys by the number and roughly what the cost is? Also, can I use a passenger side lock set in the driver's side button in order to make use of the spare keyed button and handle I have? Thanks - Scott
55 1st Chev.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Scott - the codes may be for the pins in that tumbler, but at any rate, any good locksmith can make keys to fit the tumbler you have - around here it's 5-10$
and yes you can put the keyed handle on the other side, and prolly even get the locksmith to change the other tumbler to match the key you do have so you don't hafta use 2 keys - the guys in my area do it alla time
Bill | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | The problem around here is that our local locksmith doesn't have the blanks.He will cut you a key for $2.00,if you supply the blank.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I have seen some key blanks for GM products on eBay.. always shoppin' for a bargain! | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | My favorite locksmith here in town has the blanks. I had the key copied and they had to dig for them, but they still have 'em. If you need blanks, I'm pretty sure that Jim Carter has them. American Classic might, too. I can't remember. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you might try a briggs and stratton key blank
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | A locksmith should have a book that decodes the 4 digit number you have into the depth and sequence of the notches for your lock in it's factory configuration. Problem is that it more than likely has been changed at some point in it's life to match another lock, repaired, or whatever. The best way is to let the locksmith open it up and make sure how the key should be cut to operate it. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Your locksmith probably has it. That key blank was used into the mid 60s. It's just a standard Briggs & Stratton ignition. If he doesn't have a cheap brass blank, you can get NOS chromed brass blanks on eBay for short cash. There always seem to be a few pairs listed. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | The blanks are cheaper from one of the vendors than E-bay, I think they were 99 cents each?
If you are having the locksmith re-key things, I suggest taking him the ignition, doors, glove box and possibly gas cap, one key for everything is nice.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | there is a guy in the VCCA magazine named Eric Jarvison or something like that, who re-keys locks and probably has kazillions of blanks. If anyone wants his addy or phone # I can did it up. He did some work for me, reasonable and a good job. If I can help drop me a line or post here. | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Any GM dealer should have the machine to cut the keys using the numbers,about 20 years ago i worked at a chevy dealer and I made a bunch of keys with the numbers. I did some snooping and found new key blanks for the 60s on back and made new keys for the 53 and 55 olds,67 C20 and 47 pontiac I had at the time | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | About 20 years ago these trucks were already 30 years old. Do you really think any dealerships stock parts or still have the key codes for 50 year old vehicles? Most locksmiths don't have the code books for these. You need to find an old timey shop. | | |
