2 members (TUTS 59, RLB),
121
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Ok I just looked at the bottom of my bench seat and noticed a Metal Pan bolted to the seat. She looks factory and I had a few friends look at it as well, but none remember, or have even noticed this type of thing before, other than an old Jeep. I noticed that there were two vented areas covered with a small split piece of rubber. Does this ring a bell to anyone?
Cliff59 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, it's factory, at least in the TF years - the rubber vents are to let the air out in a controlled way to cushion yer fat butt when the truck bounces over the potholes Bill | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Bill was this in ALL bench seats or an option of the Cushion seat?
Cliff59 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in all I've ever seen - I suspect it was one of the 'improvements' of the series
Bill | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | That's what I've got for my two TF seats as well. Additionaly my 59 had metal cover plates over the vent hole areas. Looked very original and stock. That metal pan made a great place for the rodents to build a home.
Joe | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | rodents huh? well I had better watch out for any mice or worse SNAKES! but then again living under MY seat those creatures would have been fumigated a long time ago with my natural methane pesticide. Cliff59 | | | | | Joined: Oct 2005 Posts: 35 Junior Member | | Junior Member Joined: Oct 2005 Posts: 35 | Yeah, actually they were in the seat. In other words on top of the pan. When I tore it apart for reupholstering, there was lots of mouse/rat droppings and one carcass it there. Oh and the odor, well it was just divine. Now a snake would be extra special. Ask a buddy to suck out the venom after being bitten in the butt and he'd probably tell you you're gonna die. I have been told of a guy working under his dash and coming face to face with a rattler living behind the dashboard. I guessing the snakes in Texas are bigger than anywhere else like all things in the Lone Star state. On the serious side, there are U shaped clips that hold the material to the frame for the seat bottom. They are a real pain to reinstall and may be made out of unobtainium. A old upholsterer can reinstall the clips but the new guys probably have no experience with them. The seat back is hog ringed like everything else. You may not be recovering your seat but if anyone else is don't throw away the clips.
Joe | | | | | Joined: Mar 2006 Posts: 1 Junior Member | | Junior Member Joined: Mar 2006 Posts: 1 | My 59 GMC has the same pan under the seat as well. The question I have is - do you remove the pan and hog ring the seat cover to the frame, or how do you attach the new seat cover under the seat?
tom | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Mine I used hog rings on the back but used sheet metal screws thru the vinyl into the seat frame. used about 35 across the front . | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | The flat metal sheet is seperate from the upholstry job. The upholstry is hog-ringed (mine had "u" clips) to the frame and the sheet metal is screwed in. I didn't have any upholstry on my seat when I got it so I'm not sure if the metal goes over or under the edge of the material.
The vent holes in also in my 56 seat. There's a metal frame that screws in over the rubber to hold it in place. I went to a garden pool place and bought a piece of the real thick pond liner rubber and cut that to fit and then sliced a slit down the center for the air escape hole. | | | | | Joined: Feb 2006 Posts: 24 Apprentice | | Apprentice Joined: Feb 2006 Posts: 24 | Cliff59, Your seat is original ..... and takes the "C" style clips for the mounting of the seat cover. I am trying to help some of you guys out by being able to find my shop. I have already posted some other replys, hopefully that help out. You can contact my shop at www.aglassenterprise.com or email me at [email protected] restoman57 | | |
