5 members (Gray_Ghost, Gdads51, Wayne67vert, 6inarow, klhansen), 86 guests, and 0 robots.
Topics128,052
Posts1,055,740
#163875 01/17/2006 7:32 AM
Ok I just looked at the bottom of my bench seat and noticed a Metal Pan bolted to the seat. She looks factory and I had a few friends look at it as well, but none remember, or have even noticed this type of thing before, other than an old Jeep.
I noticed that there were two vented areas covered with a small split piece of rubber. Does this ring a bell to anyone?
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#163876 01/17/2006 7:44 AM
yes, it's factory, at least in the TF years - the rubber vents are to let the air out in a controlled way to cushion yer fat butt when the truck bounces over the potholes grin
#163877 01/17/2006 8:53 AM
Bill was this in ALL bench seats or an option of the Cushion seat?
Cliff59
#163878 01/17/2006 10:03 AM
in all I've ever seen - I suspect it was one of the 'improvements' of the series
#163879 01/17/2006 11:11 PM
Junior Member
Junior Member
That's what I've got for my two TF seats as well. Additionaly my 59 had metal cover plates over the vent hole areas. Looked very original and stock. That metal pan made a great place for the rodents to build a home.
Joe
#163880 01/18/2006 9:09 AM
rodents huh? well I had better watch out for any mice or worse SNAKES! but then again living under MY seat those creatures would have been fumigated a long time ago with my natural methane pesticide.
grin
Cliff59
#163881 01/19/2006 1:03 AM
Junior Member
Junior Member
Yeah, actually they were in the seat. In other words on top of the pan. When I tore it apart for reupholstering, there was lots of mouse/rat droppings and one carcass it there. Oh and the odor, well it was just divine. Now a snake would be extra special. Ask a buddy to suck out the venom after being bitten in the butt and he'd probably tell you you're gonna die. I have been told of a guy working under his dash and coming face to face with a rattler living behind the dashboard. I guessing the snakes in Texas are bigger than anywhere else like all things in the Lone Star state. On the serious side, there are U shaped clips that hold the material to the frame for the seat bottom. They are a real pain to reinstall and may be made out of unobtainium. A old upholsterer can reinstall the clips but the new guys probably have no experience with them. The seat back is hog ringed like everything else. You may not be recovering your seat but if anyone else is don't throw away the clips.
Joe
#163882 03/25/2006 10:57 AM
Junior Member
Junior Member
My 59 GMC has the same pan under the seat as well. The question I have is - do you remove the pan and hog ring the seat cover to the frame, or how do you attach the new seat cover under the seat?
tom
#163883 03/25/2006 1:41 PM
Mine I used hog rings on the back but used sheet metal screws thru the vinyl into the seat frame.
used about 35 across the front .
#163884 03/25/2006 1:50 PM
The flat metal sheet is seperate from the upholstry job. The upholstry is hog-ringed (mine had "u" clips) to the frame and the sheet metal is screwed in. I didn't have any upholstry on my seat when I got it so I'm not sure if the metal goes over or under the edge of the material.
The vent holes in also in my 56 seat. There's a metal frame that screws in over the rubber to hold it in place. I went to a garden pool place and bought a piece of the real thick pond liner rubber and cut that to fit and then sliced a slit down the center for the air escape hole.
Larry Bear
55.5 Chevy 3100 Panel
#163885 04/01/2006 10:04 AM
Apprentice
Apprentice
Cliff59,
Your seat is original ..... and takes the "C" style clips for the mounting of the seat cover. I am trying to help some of you guys out by being able to find my shop. I have already posted some other replys, hopefully that help out. You can contact my shop at www.aglassenterprise.com or email me at
[email protected]
restoman57
Moderated by  ndkid275, Phak1
