0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | I'm a rookie at this. Probably everybody has taken the floor out of their cab for some reason. My truck's floor has been loose since I got it and it's rusted top and bottom, so I want to pull it out and paint it. Somehow I had the idea that that floor was going to come out without starting another hound first, but it sure looks like the hand brake lever has got to come off to do it. The brake lever is too far under the dash to let the floor out. The brake lever pivots in an assembly down below with three goodsized bolts holding a forged piece over it. Is there anything special I should know before I pull that apart? Will the floor come out some other way? Thanks, Joe H. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I was able to pull the floor pan in my 46 by adjusting the hand brake to a more straight up position and tilting the floor pan around. | | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | Thanks. I'll try it. Joe H. | | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | I've had mine out several times and I'll pass along the easiest way. Take the seat bottom out!
Tony,... 41' 1/2 ton
1941 AK named "PETEY" my buddy.
