2 members (Gray_Ghost, 1 invisible), 179 guests, and 2 robots.
Topics128,109
Posts1,056,269
Members48,439
I'm a rookie at this. Probably everybody has taken the floor out of their cab for some reason. My truck's floor has been loose since I got it and it's rusted top and bottom, so I want to pull it out and paint it. Somehow I had the idea that that floor was going to come out without starting another hound first, but it sure looks like the hand brake lever has got to come off to do it. The brake lever is too far under the dash to let the floor out. The brake lever pivots in an assembly down below with three goodsized bolts holding a forged piece over it. Is there anything special I should know before I pull that apart? Will the floor come out some other way?
Joe H.
I was able to pull the floor pan in my 46 by adjusting the hand brake to a more straight up position and tilting the floor pan around.
1946 1/2-Ton Chevy
Thanks. I'll try it.
Joe H.
I've had mine out several times and I'll pass along the easiest way. Take the seat bottom out!
Tony,... 41' 1/2 ton
1941 AK named "PETEY" my buddy.
Moderated by  ndkid275, Phak1
