| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I have been looking at those nice original style arm rests that most of our favorite part suppliers offer and I am wondering how hard is it to install them, and are they nice and sturdy?Just curious......
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Assuming you still have the thread blocks in the door, it's as simple as righty-tighty. Save yourself some grief and order the correct mounting screws at the same time. As for structure, it's a hunk of plastic with a honeycomb interior. By design, they take a downward force better than a pull, and I wouldn't hang from one. You can use it as a door pull if your doors are aligned and latch easily, but I have seen many break around the mounting screw from slamming the door. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The trick to making them last a long time is pull the door closed but stop pulling when the door slams shut Seriously, pull on the handle to get the door moving but let off on the pull as the door comes closed. (just like a quarter-mile race, HAMMER ON and let off  ) Like Hedgehog says, keep the latches and hinges adjusted and like I say, don`t use the arm-rest door pull to pull the door THROUGH the door opening
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Phillip, My sets came from either Jim Carter's and Chevy Duty. One set came with an installation template and a set of very sturdy screws (I think Chevy Duty). If your hinges and latches are good and your door is hung properly (big ifs), and if people follow Mechainiac's closing instructions, the arm rests are quite sturdy. Tim | | |
