6 members (Bill Hanlon, fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Charles in CA), 70 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
I know this subject has been covered before and I went back and did some research. An electric, heated 60/40 with a console would be great and I know a Le Sabre seat would work, but I want it to tilt forward so I can access the area behind it. What models of Buick come in 2 door varieties and would therefore have seats that would tilt forward? So far all I have been able to find are 4 doors.
:confused: :confused: :confused: :confused:
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
I was thinking about those as well, but I don't know which of those were 2 doors either, nor which would have a seat wide enough. I have found a burgundy leather seat from a LeSabre that would be great but it's from a 4 door. DRAT!!! That burgundy leather would sure look and feel great....
My 1962 Chevy C-30
Anonymous
Unregistered
Anonymous
Unregistered
then you must decide if it is totally necessary to have the seat tilt....
Junior Member
Junior Member
You might look into the GM truck seats from 2000 on. It's not a 60/40 split but a pair of buckets with a little jump-seat in the middle to make it a 3 seat bench. I'm not sure it would fit the cab perfectly but they come powered and heated if you hunt, and they tilt forward. Just an option.
Oh man, I have 60/40 power Cadillac seats in my 58. They are out of a 76, 4-door.
Trust me, it's *totally necessary* to have the seat tilt! Those babies are coming out!
IMO - If the seats don't tilt, don't put them in! Doesn't seem like that much that's useful goes on behind the seats until you can't get there!
Claymore's suggestion seems like a good one. It gives you a lot more options than a bench. That's the direction I'm planning on going when I get these leather bricks outa the booger.
Bodega Bob
http://www.submarinestore.com
Where's my tin foil hat?!?
Claymore,
Do those bench seats have the seatbelts built in?
My 1962 Chevy C-30
Junior Member
Junior Member
Yeah, they do 3 seats with 3 belts the two end seats with the belt up by your shoulder- but only from 2000 on. I got mine out of a 1500 series but Suburbans, Tahoes, Denalis and the like all used similar seats. The front "bench" is really just a pair of shallow buckets with a jump seat in the middle-so it's three pieces. The buckets will certainly fit but I'm not sure if all three will - it could be a bit too wide, I'll find out later this summer.
Here's a set on ebay- though the broken sets are awfully expensive so this one seems high to me.
http://cgi.ebay.com/ebaymotors/ws/e...1&item=7964302999&category=33701
http://cgi.ebay.com/ebaymotors/ws/e...1&item=7964304800&category=33695
i still think the buick lesabre seats are your best bet. they have electric seats and the slide forward with a touch of a button. in central indiana the quotes on these are 100.00 to 150.00 sounds reasonable to me. mostly leather. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I'm wondering if I could build a mount that would pivot in the front and lock down in the back that would allow the entire seat (bench and all, not just the back) to tilt forward? Hmmm......
My 1962 Chevy C-30
take a look at
http://home.rochester.rr.com/stphillips/59GMC/Seats.jpg
This is a set of full size truck seats in a 59 GMC. The owner told me they were a tight fit and rubbed on the doors.
Looks great though.
Blaine Dumkee
59 GMC 9314
Fort Smith NT
www.flickr.com/photos/northerngmc/
Hey northerngmc,
I like what I see in the pic. Any idea how much he paid for those? I'm not sure but I think my 62 c-30 may have an extra inch or two across to fit the seat into. Either way though, I wouldn't mind too much if the seats rubbed the doors a bit.
My 1962 Chevy C-30
Quote
I take it you are talking about installing seats inside a 60/66 Panel. I like the idea of tilting the seat forward for access, but one word of caution........safety! Make sure that whatever you install that it is installed securely to the floor. I would consider installing a latch that holds the rear of the seat down. I don't know if this will work if you have seats with the built in integral seat belts.
As far as types that will work, the 2000/2005 Tahoe/Denali/Suburbans will work. I also like the Chrysler Sebring convertible seats, they also have the integral seatbelt's. I am not sure about the height of the mounting and what it will take to install them in the truck so that you can see out of the window. Mounting is so important to avoid any injuries in a fender bender especially when you are modifying their original design.
sebring seats Check out ebay for sebring convertibles and look at the interiors. They come in leather with power, I am not sure about heat though. I have seen these go for around $250 and sometimes less. I don't like the two tone like these but the other colors look great. grin ......g
Leather seats
Suburban seats
I was thinking of a mounting system where to tilt the rear of the seat up it would be necessary to pull a pin and slide the seat back an inch or so to get it to lift up and out of the bracket.
My 1962 Chevy C-30
Anybody got a set of those 2000 up GM seats?
I would be much obliged if you could throw a tape measure across them, and let us know how wide they are.
I need to figure out if they will fit my '51...
Cheers,
mark.
'51 3100
No idea what he paid for the seats. He actually pulled them and returned the seat to stock when he sold the truck.
Check eBay or local wrecking yards for trucks. They were out of a 2001 extended cab Silverado.
Blaine Dumkee
59 GMC 9314
Fort Smith NT
Quote
Cheers,
mark.
'51 3100
Should have a bench out of a 95 here in the next couple of days that I can measure if it would help. I'm guessing the 2000 and up should be close.
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
Z
Z Offline
the only problem with that seat is it won't hide my gas tank.
i will mesure the 2005 we have at work tomarrow for you guys ok
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
Mark-some are 60/40 & others are 40/20/40. I have a set of the '40's in my '55 Bel Air. They are 22" at the widest areas. Leaves me some room for the trans. tunnel & floor shifter, may make an oak catch-all for the center someday. Mine are from a '01 Silverado, non-power. By drilling out the rivets on the OEM mounts you can attach the tracks directly to your floor & get them nice & low. The track gives you 10" of slide. Look under a OEM set at the floorpan & I would put no less than a full rocker to rocker floor stiffener to mount them to. Doug
The J.C Whitney catalog I got today has seats w/ belts built-in listed. They want over $1700.00 for a set though,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Anonymous
Unregistered
Anonymous
Unregistered
Quote
Yeah I guess so, it always seems to be that way....doesn't seem useful until you don't have it.
Moderated by  ndkid275, Phak1
