1 members (carbking), 77 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
back yard wrench turner
Sooooooo
I went out yesterday to make sure it would start and run for a Little Blue Truck Day.
The clutch had stuck to the flywheel and I couldn't shift into gear from neutral.
I started it with the transmission in 1st gear. I held in the clutch pedal, it moved forward, and gave I it a good boost with the gas pedal.
The clutch released and now all is good. Until next time. This has happened several times over the last 15 years.
I need to remember to drive it more often.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
That's something you need to remember?
Every time I see any of my vehicles, I make excuses to run errands just so I can drive them.
Wayne, put your truck into regular rotation with your other cars and when it's the truck's turn, regardless of the "mission", drive it! Don't make excuses not to drive it like it doesn't have ac or power steering, or gas is too expensive or some other bogus reason.
Vehicles don't like sitting around doing nothing. That's when they start falling apart, as you've experienced.
1950 Chevrolet 3100 (Ol' Roy)
That's less likely to happen if you wedge a piece of 2 X 4 between the seat and the clutch pedal when the truck will be parked for a while- - - - -holding the pedal down. Use the parking brake or chock a wheel front and rear.
Moderator
Moderator
2 Offline
I have been using Jerry’s idea on the 46 I have now. Big rear main seal leaking bad. If I leave it sit just for a couple days, it sticks,
I put it in second or third gear with the clutch depressed and bump the starter without the key on. It will break loose and them turn on the key and start it. I use a one by two and keep it in the cab all the time.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Crusty Old Sarge
Crusty Old Sarge
In Wayne's defense he and his Bride just returned from a lengthy trip.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
And my wife asks me "Why do you drive your truck so much?" thumbs_up
Craig
My '47 has done that a few times. As mentioned, I start it in gear with the clutch pedal depressed and the other foot on the brake. That's always worked so far. I also block the pedal down with a 2 x 4 when it's going to be sitting for a while.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Crusty Old Sarge
Crusty Old Sarge
Everything I own is older, so driving a '58 1.5 ton to work is not a big chore.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
My dad told me decades ago that he fixed them by putting them in 3rd gear then getting out and rocking them back and forth.
1950 GMC 100 Panel Truck, 1958 270,
3-spd Saginaw with BW OD,
3.73 12 Bolt Differential from a 1966 C10,
Front Disc Brakes
Hill Holder
Bought it in pieces 9-1976, driving since 6-1978
Follow in the DITY
24601
24601
This is all good stuff! Maybe someone can help me convince Peggy that the Stovebolt Mobile Command Center (e.g., the '01 AmTran former school bus) needs to do more than occasionally shift from one side of the shed to the other ... smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Leo Offline
Moderator
Moderator
With one foot on the clutch and one on the brake, how do you depress the starter button , or is that where the 2x4 comes in?
You just need a #13 shoe. grin
Mine are 13s and I'm pretty sure they wouldn't reach from the brake pedal to the stomper.
Mine has a V-8 conversion, and so doesn't use the stomp starter. It has a push button.
(But I do wear size 13 shoes also! grin )
Rich
1947 Loadmaster
We should start a fraternity or something. Men's Size 13 or MS-13? WELL MAYBE NOT THAT NAME. dang
I'm in the size 13 club!!
My truck has a button on the dash to start the motor,
Wayne
1989 Silverado
Using the emergency brake, frees up the right foot (brake pedal), allowing it to be used on the gas pedal/stomper. Living and driving on pretty flat lands, I never have the problem.
Craig
Socket Breaker
Socket Breaker
Road Trip!
