1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#1612174 09/28/2026 7:25 PM
I didn't want to hijack Roads Scholar's thread but this is related to his.
I have no problems with my steering. It doesn't jump around, there's no slack it it so I'm probably just poking a hornet's nest here. Anyway, I decided to look inside and it's packed with thick reddish brown grease.
Jon G suggest a 50/50 mix of Corn Head grease and 90w mineral oil in order for it to reach all areas of the gear itself.
I'm not removing the gear or rebuilding it. There's really no way to get all the thick grease out without disassembly.
What I was wondering is if it would make sense to add 90w mineral oil to the box and hope that the action of steering operation would mix the grease and oil together inside.
Or, should I leave well enough alone and forget about it?
1950 Chevrolet 3100 (Ol' Roy)
That's a very good question, Otto. I can see where adding the Mineral oil could loosen up the grease that's in there but I'm also thinking about it creating a leak at the seal on the shaft. I "overhauled" my gear box by installing new bushings and a new seal and then filled with cornhead grease. My initial issue was play in the output shaft ( a lot ! ). If you end up going with the oil added, let us know how it turned out if you would.
Ron - - Dusty53
1954 Chevy 3604
Otto - I did what you are describing and it promptly ran out my pitman seal. Bright side, found and eliminated one more leak.
Once I replaced the seal, I did the 00 cotton picker grease.
1951 3100
Steering works, no leaks. I should probably just leave whatever kind of grease is in there alone. No need to open another can of worms.
Sounds like a plan. Don't like worms.....unless they are on a hook.
Ron - - Dusty53
1954 Chevy 3604
