8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna),
154
0
Mod | | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 87 | Folks.
I need to change the pushrod cover seal on my 216, got the seals, pretty okay with the process.
Question, is there any thing a person can do to divert the oil away from this collection point at the rear bottom of the cover.
Steve | | | | | Joined: Sep 2013 Posts: 1,364 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,364 | Rig a parking spot so the front is about 3 degrees lower than the front. No oil pooling at the back of the engine.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Mar 2007 Posts: 3,398 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,398 | I would think a quality gasket, clean surface and proper sealant would do the trick.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | This stuff is good, but it's E$$$$PENSIVE! We used to use it in situations where there was a chronic leak due to slightly warped flanges, etc. It's a thick liquid that's applied in a thin bead from the tube and spread with a putty knife, right before assembly- - - - -with or without a gasket. www.ebay.com/itm/236671458753?Jerry
| | | | | Joined: Sep 2013 Posts: 1,364 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,364 | Jerry, how was it when time to disassemble?
RonR
| | | | | Joined: May 2015 Posts: 11,069 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,069 | I could be wrong, but I think there's a drain hole for oil at the rear of the block. I used RTV on both sides of the gasket. Works fine.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2021 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 87 | Thanks folks, yeh I was going to use some master gasket sealant on both sides of the cork gasket, it’s my go to product as well (ex aircraft mechanic)
Was hoping someone developed a mod that takes the drained oil from the head away from that back corner | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | With the side cover off, be sure to make sure the metal around the bolt holes are not distorted. Overtightening in an attempt to seal leaks leads to distortion of the metal. Flatten with a hammer gently on a flat surface. Then use the gasket sealer of your choice. In my experience it is best to accept a little bit of seepage and not fret too much because it is nearly impossible to keep the area dry.
Kent | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Jerry, how was it when time to disassemble? Warm the cover up a little with a Propane torch- - - - -the sealer releases easily with just a bit of heat. Jerry
