3 members (RoadsScholar, Otto Skorzeny, 1 invisible), 197 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
#1610071 08/25/2026 10:53 AM
Folks.
I need to change the pushrod cover seal on my 216, got the seals, pretty okay with the process.
Question, is there any thing a person can do to divert the oil away from this collection point at the rear bottom of the cover.
Steve
Rig a parking spot so the front is about 3 degrees lower than the front. No oil pooling at the back of the engine.
RonR
1970 340 Duster
1964 CJ5
Crusty Old Sarge
Crusty Old Sarge
I would think a quality gasket, clean surface and proper sealant would do the trick.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
This stuff is good, but it's E$$$$PENSIVE! We used to use it in situations where there was a chronic leak due to slightly warped flanges, etc. It's a thick liquid that's applied in a thin bead from the tube and spread with a putty knife, right before assembly- - - - -with or without a gasket.
www.ebay.com/itm/236671458753?
Jerry, how was it when time to disassemble?
RonR
1970 340 Duster
1964 CJ5
I could be wrong, but I think there's a drain hole for oil at the rear of the block. I used RTV on both sides of the gasket. Works fine.
Thanks folks, yeh I was going to use some master gasket sealant on both sides of the cork gasket, it’s my go to product as well (ex aircraft mechanic)
Was hoping someone developed a mod that takes the drained oil from the head away from that back corner
With the side cover off, be sure to make sure the metal around the bolt holes are not distorted. Overtightening in an attempt to seal leaks leads to distortion of the metal. Flatten with a hammer gently on a flat surface. Then use the gasket sealer of your choice. In my experience it is best to accept a little bit of seepage and not fret too much because it is nearly impossible to keep the area dry.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Warm the cover up a little with a Propane torch- - - - -the sealer releases easily with just a bit of heat.
