8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#1602394 04/22/2026 12:21 PM
I am helping a friend with his 46 1/2 ton
We are going to replace the wiring and change to 12 Volt
I don’t see any fuse box in it ?
The replacement wire kits are not showing a fuse box either
He wants a one wire Alternator as well
Any suggestions for this ?
52-Mobil #1602398 04/22/2026 1:19 PM
I made my own wire harness to fit my '37s needs. No fuses, all self-resetting circuit breakers. My truck has A/C, lights, and horns, no other accessories so running wires was easy.
I ran all the wires to a box under the seat, if something goes wrong, I lift the seat to check for problems, not crawl under the dash. I helped scrap out a school bus, so I had tons of wire all numbered and color coded. In 26 years, I haven't had one issue with the electrical system, not even a light bulb out. I ran a ground wire to every light from a main ground stud just off the battery, so no need to grind paint off or worry about grounding issues.
Plan ahead for future accessories, I knew at some point I was adding A/C, so I added a heavy power and ground wire up to the dash area when I made the harness, same with ignition, I used a 12 gauge wire to the points distributor knowing I was adding HEI down the road when money became available.
Since it's a truck, add a trailer light harness plug, you may never use it, but the next guy might.
The original harnesses didn't use fuses, they were not needed. The head light switch had a built in circuit breaker of fuse, nothing else was installed that needed fused.
52-Mobil #1602400 04/22/2026 1:42 PM
This wiring diagram on the Chevy Old Car Manual is listed as 1946, but is named 45truck.jpg
The only fuse shown is part of the light switch.
52-Mobil #1602402 04/22/2026 2:26 PM
G Online: Sleepy
Adapt a 1958-59 wiring harness that has a fuse block.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Joe H #1602408 04/22/2026 6:43 PM
Thank you
Joe H #1602409 04/22/2026 6:47 PM
Alternator one wire to Amp Gauge and then to Battery ?
A 10 gauge wire ?
I thought a one wire alternator went straight to the battery ?
52-Mobil #1602502 04/24/2026 4:58 PM
Alternator and loads on one side, and battery ONLY on the other. If loads are on the same side as the battery, the amp gauge will not show a discharge if the alternator fails.
klhansen #1602509 04/24/2026 6:54 PM
... and if the ammeter reads a charge with the headlights on and the engine off swap sides with the wires.
52-Mobil #1602566 04/25/2026 1:23 PM
I deleted the wrong information, hope it didn't mess up anyone. My way would read charge but not discharge if I read it right on a couple other forums. The way it's described above, it read both directions.
I have go look at my truck and see how its wired, I know it charges, not sure I ever seen it discharge.
