| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 452 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 452 | On my 46 l sourced my t5 cable at my local NAPA, the length is the criteria
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Oct 2023 Posts: 327 'Bolter | | 'Bolter Joined: Oct 2023 Posts: 327 | Jerry, does your speedo use that square drive end? And is the cable actually for a 46 application? That will be easy if that's the case. My '36 cable on the transmission end uses a keyed design that doesn't insert into the T5 and I don't know where things changed along the way, so not sure what works with what.
Thanks. | | | | | Joined: Sep 2020 Posts: 452 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 452 | If you are going onto a t5 forget about “original”, it will only confuse you because a T5 is (likely) different than stock. I’ll send a picture or 2 of the cable/ends but I’m not near my shop/truck for a few days. Yes I believe The Speedo end is sq drive. You can look up 1982 S10 Speedo cables as a starting point.
Chuck
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Oct 2023 Posts: 327 'Bolter | | 'Bolter Joined: Oct 2023 Posts: 327 | For future reference, the cables I posted above sold by Classic Parts and Filling Station will work with a square drive Chevy speedometer ('34-46) and a T5 if it's long enough for your application. My '36 speedometer takes a 7/8-18 screw cap, and my '85-86 S10 T5 also takes a 7/8-18 screw cap with the .104 drive pin. I called Classic Parts and confirmed the transmission end is the correct screw cap and drive pin size for a T5. The problem may be the length, though. I might be able to just barely get it there by running it straight to the transmission, across open space, but it may be tight and could come into the transmission at a hard angle. I'd much rather run it along the frame rail and over, so I'm going to have a custom cable made from this place. https://www.texasindustrialelectric.com/speedo.aspEDIT: Ordered from this place instead. Much cheaper. https://www.speedoservice.com/contact/
| | | | | Joined: Oct 2021 Posts: 6,941 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,941 | If a hard right angle is causing a problem with your speedo cable, right angle adapters are available with 1:1 ratio to screw into the side of the tranny and allow the cable to screw into the adapter at a straight run.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Oct 2023 Posts: 327 'Bolter | | 'Bolter Joined: Oct 2023 Posts: 327 | Wanted to recommend this place again. I called him yesterday, and he called today telling me it's done, boxed, and will be shipped by the end of the day. Custom cable made and shipped for less than the price of the Filling Station or Classic Parts even before shipping costs, and a foot longer. Real nice guy too. Didn't get it yet, so I'll post any issues if I have them, but I don't anticipate any. https://www.speedoservice.com/contact/
