4 members (Goach2, Wally / Montana, Wayne67vert, 1 invisible), 130 guests, and 6 robots.
Topics128,201
Posts1,057,276
Members48,466
Does anyone know if the cables in the links below will work with a T5? My stock gauge is the square drive, which this cable has, but it's the other end I'm not sure of. Is it the proper drive type and screw cap to fit the mechanical speedo T5 tail housing? Or if you guys have another source for a cable, that would be great as these are pretty salty.
Ron
https://classicparts.com/1934-46-speedometer-cable#product.detail.description
https://store.fillingstation.com/detail/SA-497/Chevrolet_19331946_COMPLETE_SPEEDOMETER_CABLE_65.html
On my 46 l sourced my t5 cable at my local NAPA, the length is the criteria
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Jerry, does your speedo use that square drive end? And is the cable actually for a 46 application? That will be easy if that's the case. My '36 cable on the transmission end uses a keyed design that doesn't insert into the T5 and I don't know where things changed along the way, so not sure what works with what.
Thanks.
If you are going onto a t5 forget about “original”, it will only confuse you because a T5 is (likely) different than stock. I’ll send a picture or 2 of the cable/ends but I’m not near my shop/truck for a few days. Yes I believe The Speedo end is sq drive.
You can look up 1982 S10 Speedo cables as a starting point.
Chuck
2023 Miata RF Club
For future reference, the cables I posted above sold by Classic Parts and Filling Station will work with a square drive Chevy speedometer ('34-46) and a T5 if it's long enough for your application. My '36 speedometer takes a 7/8-18 screw cap, and my '85-86 S10 T5 also takes a 7/8-18 screw cap with the .104 drive pin. I called Classic Parts and confirmed the transmission end is the correct screw cap and drive pin size for a T5.
The problem may be the length, though. I might be able to just barely get it there by running it straight to the transmission, across open space, but it may be tight and could come into the transmission at a hard angle. I'd much rather run it along the frame rail and over, so I'm going to have a custom cable made from this place.
https://www.texasindustrialelectric.com/speedo.asp
EDIT: Ordered from this place instead. Much cheaper.
https://www.speedoservice.com/contact/
If a hard right angle is causing a problem with your speedo cable, right angle adapters are available with 1:1 ratio to screw into the side of the tranny and allow the cable to screw into the adapter at a straight run.
1950 Chevrolet 3100 (Ol' Roy)
Wanted to recommend this place again. I called him yesterday, and he called today telling me it's done, boxed, and will be shipped by the end of the day. Custom cable made and shipped for less than the price of the Filling Station or Classic Parts even before shipping costs, and a foot longer. Real nice guy too. Didn't get it yet, so I'll post any issues if I have them, but I don't anticipate any.
