7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny), 102 guests, and 3 robots.
Topics128,071
Posts1,055,901
Members48,429
#159785 08/28/2007 12:45 AM
I scored a nice 60 gallon 2 cylinder Quincy compressor off Craigslist for $250. It was legit- the seller is an industrial compressor dealer and he was upgrading their back shop. It came with a spare head and oil pump- this thing is like an automotive motor. It has an actual oil pump, poppet valves, unloader system, and a Baldor motor. You can either leave the compressor motor running constantly and use the unloader to regulate pressure, or use the tank switch.
Its a horizontal unit, weighs about 400 pounds. Its going to live in the attic space of my shop if I can figure out how to hoist it up there without killing someone.
Audios to my 30 gallon Coleman, how I hated ye.
Paint & Body Shop moderator
#159786 08/28/2007 2:24 AM
Nice SCORE! Now you can keep the neighbors up late. :rolleyes:
Before you put that in the attic, check and make sure the ceiling joist will hold. That's a load.
Larry
I don't own a vehicle that isn't old enough to drink.
#159787 08/28/2007 3:47 AM
you now have what is considered by most to be the best. Nice catch.
#159789 08/28/2007 7:04 AM
It's not quite big enough to run a big blaster, but it keeps up with my 12 cfm HVLP gun no problem. I set it up in a corner of my shop for now next to the 240V outlet. It has a slow leak in the water drain valve, but that will be easy to fix. It sounds nice too, a nice soothing thub thub.
#159791 08/29/2007 2:31 PM
Anonymous
Unregistered
Anonymous
Unregistered
You know I have been thinking of relocating, Do either one of you guys have a outside connection? I have plenty of hose.
Mike
#159793 08/30/2007 10:45 PM
I got a Champion 5 hp 2 stage commwecial, I can run my cabinet all day and never run low. What I like is that it has an automatic water drain after the compressor stops.
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
#159794 09/07/2007 7:24 PM
Anonymous
Unregistered
Anonymous
Unregistered
Joe
Your too nice, Now we all know your price.I can always be talked in to BBQ too.
Moderated by  MNSmith
