3 members (farmallb, DaveV, Peggy M), 48 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#159722 07/26/2007 5:27 PM
I just purchased a pressure blaster & was wondering what would be the best way to set up the blasting area, do I just lay down some tarps or do I need to have the area enclosed, can you use the media again & again. I would appreciate any help with this as this is my first time with the blaster.
Thanks James
If it was easy, everybody would be doing it.
#159723 07/26/2007 5:43 PM
From my Wheel Restoration How-To article
is the following sandblasting section:
Quote
Sandblast Wheel
Gather Tools: Tarp, air compressor, pressure blaster, sand bucket, dust pan, funnel, stool, blasting coveralls, respirator, blasting hood, gloves. The tarp is a 20' x 30' Silver Tarp from Northern Tool. The air compressor is a 3-1/2 hp, 20 gal, 2-stage, 175 psi model from Sears and is light for this kind of task but workable. The blaster is a 110 lb pressurized abrasive blaster from Harbor Freight. The funnel came with it and I stretched insect screen secured with a bungee cord over the funnel mouth to filter the sand. The sand bucket and dust pan are from Home Depot. The stool is a mechanics roller seat from Northern Tool. The heavy-duty blasting coveralls came from Harbor Freight. The respirator is a multi-purpose model from Sears. The blasting hood is an Eastwood Company deluxe model. The gloves are mechanix gloves from the Eastwood Company and are light for blasting work (keep the nozzle away from them).
Blasting: Spread and anchor the tarp. I use precast concrete paver samples we have laying around the Krash Lab. This works well if the wind is below ten mph. Setup the air compressor and pressure blaster. I fill the pressure blaster with a bucket of sand maximum (about fifty pounds) using the screened funnel to filter it. Replace the filler cap (a drop of oil smeared on the o-ring helps it to seat). Pressurize the blaster (I use about 100 psi), don protective clothing and respirator and get-r-done. There's a lotta waiting on the air compressor but that's where zen meditation enters the picture.
Re-filling: After cycling thru the sand, close off the valve between compressor and blaster and BLEED OFF ALL THE PRESSURE IN THE BLASTER TANK before removing the cap to refill with sand. This is a good time to get a drink of water to re-hydrate yourself. Un-anchor the tarp and pull up the corners to herd the loose sand to the center of the tarp for recovery and recycling. With low wind and the tarp spread to its full 20' x 30', I recover approximately 80% of the sand for each cycle thru the blaster.
Continue the above steps until you finish the wheel(s) or grow tired. At the end, you should have something that looks like this (Yes, it is the same wheel!). There's almost something religous about clean metal freed from rust. Too bad you can't take a blaster after a tarnished character. I try to finish without any sand left in the tank to lessen the possibility of clogging during storage. Any leftover sand is stored in the bucket..
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#159724 07/26/2007 9:55 PM
Man, that is over kill(joking) I just take them down to the local shop (that sand blasts heavy machinery) and pay them $65 per hr. The nozzle on their gun muct be 1.5 in. they blast a heck of a lot in 1 hr.
#159725 07/27/2007 2:24 PM
Gazim, gotta kind of agree with ya there. I took my four split rims, wheels and rings to the same type of guys and they did the whole bit for $25.
Of course on the other hand, if your gonna do a bunch of blasting it might pay to have the equipment at home.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#159726 07/27/2007 2:36 PM
LAROKE, One thing you could do to increase your blast time with a small compressor is get a second tank and hook it in series to your compressor. This would also give you longer "zen" time inbetween.
#159727 08/03/2007 9:28 AM
Thanks for the info Laroke, I appreciate it
James
#159728 08/05/2007 6:41 AM
mine seems to work better with a real long hose like 100 feet or more with the pressuer turned down to 100 seems to run more steady and smooth
Moderated by  MNSmith
