5 members (55shaker, Gdads51, Ponchogl, DadsFirstPickup, stlcardinalsguy), 125 guests, and 1 robot.
Topics128,054
Posts1,055,782
#1596710 01/27/2026 10:30 PM
D Online: Content
Probably a silly question but.....do you folks use a shellac or other gasket sealer when installing the gaskets on the rear end cover? I haven't done much wrenching in the past 20 years, but back in the day I remember using the shellac as well as just RTV silicone. What is considered correct?
Brendan
1940 Chevrolet 1/2-Ton Pickup
Restoring Dad's old truck
I don’t know about the more experienced members but I just replaced the gasket on my differential cover and it still leaked! Prior owner didn’t even have a gasket- just some gasket material. I took the cover off, and applied some gasket adhesive to the cover side of the gasket and it sealed it up. I use 3M Yellow Super Weatherstrip and Gasket Adhesive. I also had to replace all my bolts as they were stripped at the threads to torque properly (I think it’s 30-50 foot pounds
1951 GMC with positive ground. Engine is a ‘54 Chevy passenger car (Serial Number 0024472F54Z) with a ‘56 head (casting code on top of head 3836848 GM 4), Casting Code (on passenger side on side of head B56 848 850)
51 Jimmy #1596730 01/28/2026 5:01 PM
No wonder bolts failed, way to tight.
BC
1960 C60 pasture art
Agree that 30-50 foot pounds is too tight and likely distorted the cover. 20-30 foot pounds would be more like it. Also, since the bolts go into the differential carrier, it is important to put sealant on the bolt threads to keep gear oil from seeping out. One product I like for this application is Permatex "The Right Stuff". I know, a stupid name but this is a type of sealant that works better than routine RTV. You don't get the seepage later on. It has more adhesive qualities than regular RTV so I wouldn't use it where you routinely remove the part for maintenance.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
On the rear end cover I use a gasket and a sealant. I had been using a silicone RTV type, and recently I started to use Permatex Aviation form-a-gasket sealant liquid. I figure if it is for use in Aviation applications it will work well in Automotive. Absolutely do not get it on anything other than on the gasket or metal part, it is very difficult to get off your skin, so I suggest wearing gloves. It's a brown liquid much like the old Indian Head gasket sealer. 25-30 pounds torque on the bolts should be sufficient.
1938 half ton pickup
