0 members (), 137 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
back yard wrench turner
Those of you that have bucket seats in your 36, 37, and 38's. What seats did you use. I'm 6'1 and 240 lb. My bench from a mini van is not comfortable.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I have a 2004 Ford F-150 Lariat extended cab with bucket seats.
The seats are quite comfortable for me and the seat belts are built into the seats.
I don't know if they would fit into the small cab of a 37 Chev pickup though.
I used 2000 Silverado seats that have seat belt built in them when I built a 41 master deluxe. There was room also for a console, but I would think them your pickup would be to narrow for the console.
Good luck, Wayne! Not much room in our trucks until you get to the AD style. I was OK when I first built my 37 but for some reason my tummy now hits the steering wheel and I'm using a small after market and column tilt.
.....Seems I remember checking out the Honda seats but can't remember why or why not.
I feel you pain!
I looked at the current seat I have and determined it was not leaning back as far as it should. It feels like I'm sitting in an old church pew.
I moved it 2 1/2 inches forward, dropped the rear 1 1/4 inches and was able to get the seat back to lean by 2 inches.
I have it adjusted it so it is now tolerable for me. But this cab is still very tight.
Wayne
1989 Silverado
Crusty Old Sarge
Crusty Old Sarge
Wayne, I'm not sure GM made that Cab for yor 6' 2 " frame. I have seen several early Cabs with F@&d Ranger bench seats. I believe they are not quite as deep.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I found the same thing in my '37, the back of the seat was too straight up. The buckets I tried never felt right, so I used the stock seat. After moving some padding around and setting the back on the forward most mounting position, it is much better. I also added stiff foam to the front edge of the bottom cushions, then raised them up to a steeper angle, it sets kind-a-like a bucket seat, not like the sofa it was before. I'm only 5' 9" so I have a little more room, it's no surprise they made the cabs bigger the following years.
Moderated by  ndkid275, Phak1
