| | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | I just bought a 1952 dump truck this week and everything I want to work on so far is attached with bolts with heads I've never seen before. Can someone please tell me what you call these? Thanks! [img] http://www.morethanmeetstheeye.com/52/mysteryfastener.jpg[/img] | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Be prepared for them not to know what you're talking about, though. The clutch head hasn't been used for quite some time, exept for some odd trailer applications. If you can't find them at the flaps or hardware store (Sears doesn't carry them in the stores BTW) Snap-On, Mac, Matco, and S&K still have them. You might check with a local repair shop and find out when the tool guy comes around, and if it's OK with them if you talk to him at their shop. Some places are touchy about that. I've been booted off of a few car lots trying to catch the tool guy 'cause i couldn't catch him at work.
Bill Burmeister | | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | Those are the clutch head screws. Check out evil-bay,,i recently saw a set of screwdrivers on there. | | | | | Joined: Jun 2007 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 32 | Thanks everyone! I asked a couple hot rods guys and an older gent at Auto Zone and no one had a clue. That photo is a door latch bolt's. Smaller ones are used on the brake light switch. Thankfully a little WD40 took care of a sticky brake switch, and there was no need to remove it. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | The clutch head drivers are readily avaible at many places. NAPA usually carries them,but they are a little pricey.Most of the mail order outfits,Chevy Duty,Brothers,etc.sell a complete set for under $20. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | You can use a flat blade screw driver in a pinch. You have to make sure you're flat & straight with the screwdriver if you do because it's easy to round out the hole using a flat blade.
| | | | | Joined: Mar 2005 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 76 | american classic truck parts or jim carter or just abotu every old parts stores sale they . ebay to.thanks | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | as Tiny stated A flat tip will work I have had good luck with a flat tip screwdriver , but search through your collection to find one that fits in as tight as possible to avoid strippin out the head. | | | | | Joined: Jan 2007 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 60 | You can get a nice set of 4 clutch head screwdrivers from Classic Industries, page 456 of their truck catalog for $19.95. I also got clutch head bit drivers from Matco Tools that work great with a ratchet. I know a couple of Matco guys in the Chicago area. Let me know if you need the contact info. | | |
